So what is the downside of wrapping a car?
2013 C63 Black Series
Seems to be the trend, wrapping a car in either clear form to protect the original paint look or matte finish. What is the downside other than cost? As someone that has no idea the engineering behind the film, I would be worried that it would damage the paint. Isnt the factory paint meant to "breathe"? Is there a risk that the film will "lift" the paint, etc.? Guess I am wondering what the detractors would say. Talk me out of wrapping my Black Series when it gets here. Thanks!
2011 C63 Calcite White
I think you gotta be careful when taking it out for a hand wash, i m not sure though lol only thought of it because one of the many car hand wash companies in my city had hella complains about ripping their vinyl wrap
All my answers are going to be based on my understanding of true protective wraps, not vinyl wraps (whose sole purpose is to change color, not protect).
Yes, there's a risk it'll peal off paint when you remove the wrap. If you have a good installer install it properly, and have a good installer (probably the same people) remove it when you want it removed, you likely have nothing to worry about. Also, so long as the paint has cured properly, you'll likely have nothing to worry about. (This is more of an issue for resprayed panels, as opposed to factory paint.) Also, MB supposedly uses some of the best clear coat out there, and it's one of the hardest on the market.
I don't think paint is meant to breathe, breathing implies oxidation, and oxidation is bad. This is why people put layers and layers of wax on top of sealants, etc.
I will be wrapping my BS when it arrives. And these guys will be doing it: http://www.premiermobilegroup.com
They've posted a few threads on MBWorld, but they generally post on other (more generic) sites. Most of the cars they do are high end / exotic / rare / limited editions. And they go as far as removing easily removed panels to ensure that the wrap goes on the inside to prevent pealing and to avoid having those unsightly lines.
I will be doing a matte wrap, so maintenance is as simple as washing gently, and nothing more. There's a matte sealant out there (Dr. Beasley's) that I will also use to protect the wrap once every ~6 months (same recommended care for matte paint, basically). If you do a clear/glossy wrap, the recommended care is the same as the recommended care for glossy paint.
If you get it done by a really awesome installer, cost is generally pretty high... can be up to 3x more than a non-awesome installer. But, in the end, you do get what you pay for.
As for material, there are three out there that people swear by. Prestige Films (what Premier uses -- see link above), 3M VentureShield, and XPEL. All three have both glossy and matte film.
Vinyl wrap doesn't protect since it's 1 - 3mm thick. The ones mentioned above are 6 - 8mm thick.
Last edited by GrnLantern; 09-24-2012 at 10:45 PM. Reason: Added detail about matte paint sealant
Not if wrapped properly, or if you take it to a proper detailer (or both).
(Or do it yourself if you're that worried.)
In the end, the wrap is supposed to protect your wrap and bring you peace of mind. If it doesn't, then you wasted your money.
The only time I've seen film damage are from people that power wash up close, that rips and tears the film.
I've wrapped my last 4 cars. 2 clear, and 2 matte. If anything, it makes washing much easier. Zero water spots, tougher than clearcoat. I'm super lazy now when it comes to car washes. Sponge and towel, which would normally destroy clearcoat. The film is tough to scratch.
Yeah, I heard that too. I'm hoping that won't be the case, though, I believe Premier has a 5 year warranty against bubbling or peeling.
Big White Marshmallow
Just Wrapped my car Matte White, hand wash my baby every night, with very mild soap, not a lot of elbow grease though either. When I first spray down the car majority of the dirty comes right off, I use some all purpose cleaner for harder spots, but I am really happy with the turn out..... Let me know if your local in the bay area, I have a good connection.
I am not as concerned about the cost, bubbling, etc. I just want to know that there is no way the film will damage the paint, either going on, staying on or when coming off...
2017 Mini Cooper S Clubman ALL4 - British Racing Green
If done correctly, the paint will be fine. However, the biggest issue, is that if there is any debris, dirt or contaminants under the wrap when it is installed, that stuff will act like sandpaper and destroy the paint in that area.
https://mbworld.org/forums/4780429-post9.html
You can tell when the film is getting old, it has a brittle feeling to it, instead of soft plastic.
Even then, the only difference is that old worn film/glue is a PITA to remove. Once removed, and detailed, the paint is good as new.
Watch out for crappy installers. There's a member here that went to a local shop who's run/hires high school kids that don't give a *****, and cut the paint when trimming the 3m. Paint cut marks all over the car!
Any good installer will detail each panel before install.
Yup. I can't remember the last time I kept a car for 5 years.
Either way, just get it re-wrapped every 5 and you'll be fine. The important things:
1) Find a very qualified installer.
2) Use only the finest materials.
3) Re-wrap every 4 or 5 years depending on abuse and where you park and what the climate/weather is like in your area.
That's what I'll be doing.
Any suggestions on finding a great source for wrap in Austin, TX? My takeaway from this thread is that the "who" does the wrap, makes all the difference in the world. I dont mind spending a premium to have it done right. I am thinking about copying Rage's car
Ideally, would prefer to not spend an additional $2k for shipping round trip out of my city. That starts to make this cost prohibitive, if you budget up to $5k+ for the wrap itself.
thanks
thanks
Here's your template...
Let me know if you need more info.
Administrator
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
Ok who is my best wrap vendor in Orange County, CA??
Anyway, tell the truth, or seek help please
