A/C Compressor destroyed
Hi guys
So I just had my A/C compressor replaced for the 2nd time and I was wondering what made it break down the way it did. The tech told me that the compressor literally fall apart...
There is a year warranty with the new compressor but still...
He told me it's a common problem with the 63 engines (M156)... Is there something that I'm doing wrong? Maybe it's because I downshift a lot at high rpms?
Any help would be appreciated... Thanks!
Common problem with the M156??? Never heard that one and not sure how a compressor issue could be related to the block it's mounted onto. Perhaps the heat emitted by the M156???
C63
If the AC system is not properly flushed out when the 1st one broke then there will be tiny metal particles in the lines ( basically sanding the inside of the new compressor ). Those metal particals will ruin the compressor. One theory, I say say for certain because the thech might have flushed your system out properly. Ragging on the car left and right will ruin the AC too. When you road race the AC is off not on so thats another way to ruin it too.
C63
When you "step on it" the AC system shuts off ( compressor ) as soon as the rpm's drop down the AC compressor clutch kicks back on. When you road race the AC is typically off. When your constantly stomping the gas what I just explianed happens over and over again on/off on/off and so on. The compressor is controlled by many paramiters ( rpm, temp, line pressure high/low line pressure ) so the best thing to do is just turn it off if your going to be "stomping the gas over and over" that way you don't tax the daylighting on the AC compressor. I hope this helps. Maybe someone with more knowledge on this can chime in.
That explains many things. I always downshift at high RPMs... I thought I was helping the brakes (and my wallet) but it looks like I'm gonna need to stop doing that unless I want my car to back to the shop again.
2012 C63
I've read conflicting articles about the effects of engine braking, but personally I think brakes are a lot cheaper to replace than your motor/transmission.
96 and 08 911 turbos
2006, ac, air, cl55, class, clutch, compressor, conditioner, destroyed, florida, jacksonville, mercedes, replacement, s500, w114, w204
