C63 AMG (W204) 2008 - 2015
ECU tune and camshafts
Old 11-24-2012, 06:46 AM
AD_91111's Avatar
C63 AMG
Hello guys,
I have question about ECU tuning.
I had my ECU tuned and after time my camshafts got damaged i am really not sure why it might be from the tune.
Should I re-tune the car because of replacing with the new camshafts?
Thanks all =)
Old 11-24-2012, 07:31 AM
63c
63c's Avatar
2009 c63 + 2017 coupe c63 edition1
Hmmm, who tune your car ?
Old 11-24-2012, 09:32 AM
4ramin's Avatar
2010 C63,1989 944 Turbo, 2018-GTR, GLC63S
Here we go
Old 11-24-2012, 09:47 AM
AD_91111's Avatar
C63 AMG
I tuned it in Dubai , http://www.chipcentric.me/ and guy name Murad he is from Turkey.
Old 11-24-2012, 10:15 AM
Jons95c36amg's Avatar
02 CLK 55 AMG,09 C63 loaded with P30
How do you know the cams are damaged?
Old 11-24-2012, 10:44 AM
AD_91111's Avatar
C63 AMG
I heard that there noise coming from the engine with the time it was quite but once i turn the the car on and it sounds very loud, I took the car to the workshop and they open the head and they found that one of 4 cams was making the issue and the others almost to be same so I changed them all and it cost me about 3500$ stock AMG cams .
Old 11-24-2012, 11:37 AM
bluejae's Avatar
'10 C63
i find it hard to believe a tune could do that...
Old 11-24-2012, 12:21 PM
b16
b16's Avatar
2009 C63, 2000 ML 430, 1994 Del Sol Vtec
no way a tune can damage cams. might be excessive bucket wear which there is a class action suit over.
Old 11-24-2012, 01:07 PM
AD_91111's Avatar
C63 AMG
thanks guys ,but should I retune again since I bought new cams and installed them ?
Old 11-24-2012, 01:34 PM
BerBer63's Avatar
2009 C63
yes
Old 11-24-2012, 03:11 PM
Merc63's Avatar
C63 AMG
The tune can control the cams.
These are hydraulically actuated DOHC engines. The cams are adjusted by the "cam adjusters" with oil pressure through a rotor and stator.
Noisy loud clicking/rattling can be heard on start up from the engine and is most likely the cam adjusters. I have had 2 M156 engines and both needed new cam adjusters around 60,000km.
I find it hard to believe the actual cam shafts were the issue. Lifters would need to be replaced with new cams, this is a rule across all engines. Can OP confirm if cam adjusters or shafts were replaced, and if the noise is gone now?
Old 11-24-2012, 03:25 PM
AD_91111's Avatar
C63 AMG
And it would be the same for removing the cats from exhaust for high flow ? My friend told me that even if u removes them you have to retune so if its like that ,I will re-tune after removing them.
if anybody knows i would very thankful
thanks
Old 11-24-2012, 03:27 PM
DuaneC63's Avatar
AMG GLC63. Audi R8
It's not the cams, but the lifters that cause the damage to the cams. MBZ has a replacement lifter from the SLS engine. Hopefully your shop was aware of this and changed all the lifters when they changed the cams.
Old 11-24-2012, 04:41 PM
AD_91111's Avatar
C63 AMG
the lifters is changed too with the new 4 cams you have to change them with new cams ,the noise is completely gone after changing the cams with lifters
Old 11-24-2012, 04:47 PM
AD_91111's Avatar
C63 AMG
Hopefully yes,I hope this will not happen again ..I thought from tuning but that issue with 63 Engines by the way it happened when the car was on 134K KM about the services I was taking care of all of them in time.
Old 11-24-2012, 05:27 PM
Merc63's Avatar
C63 AMG
Would love to have seen some pics of the lifters and cams.
Old 11-24-2012, 10:54 PM
AD_91111's Avatar
C63 AMG
Sorry just I found only one pic,zoom in the middle you will see there is small scratch or its like a crack.
http://db.tt/5SpX3DSD
Old 11-25-2012, 11:21 AM
63c
63c's Avatar
bro please if you want anything PM i will help you
Old 10-13-2013, 01:15 AM
ronniecr_2000's Avatar
MB R-500 Model 2006
My R-500 2006 cruise control, SRS not working. Will ECU remap will help solve the issues? Help please?
Old 10-13-2013, 03:33 AM
Zeee_Q's Avatar
C63, 335i
Try posting in the R class forum section. There's probably more members over there with knowledge of any issue with your car. Highly doubt a ECU remap (I'm assuming you are talking about a tune) will solve your issue.
Old 10-19-2013, 12:25 AM
DuaneC63's Avatar
AMG GLC63. Audi R8
Originally Posted by AD_91111
Hello guys,
Thanks all =)
If your car is pre 2011, it was not your tune that damaged you camshafts. The design of the lifters is faulty (not the camshafts). They were replaced with lifters out of the SLS63 during MY 2010. If you have to replace your cams, you might as well pull the heads and replace the head gaskets, new design head bolts, and new designed lifters.
Old 10-19-2013, 03:00 AM
bhamg's Avatar
C63 AMG
Hope you sort it out. The GF however, got great results from Murad:
http://www.murad.com
Old 10-19-2013, 03:24 AM
aussie e55's Avatar
2009 C 63
hi bhamg
you sucked me in very funny lol.
Quick Reply: ECU tune and camshafts
