Problem with Eurocharged MyGenius handheld programmer
#77
SPONSOR
#78
SPONSOR
It uploaded 1 tune and won't let me load any others. It shows "the status of your my genius does not permit this action". This message appears next to the upload button, which is grayed out.
When I plug the genius up to my car, the tune is not listed on it anywhere. What gives?!
#79
SPONSOR
#80
SPONSOR
Ok, I just sent like 15 tune files out to various customers.
Has everyone received their files and gotten them loaded?
#83
SPONSOR
Feel free to give me a call and I can walk you through it.
#84
Clk63 Black, G55,993
just plug in obd,finish Ecu programming write., but I it didn't show "writing ecu completed".
Cold start sound different ., I still have the cel from the LTHeader.
#85
Thanks Jerry. I appreciate it but I'll wait for Velos to respond.
If they don't resolve the issue in 24h I'll definitely contact You
#86
SPONSOR
1. The C63 cannot be "READ" via OBDII. The only options you should see are PRT Identify and ID. You need to PRT Identify first, then ID. After the ID is done, email your file to Velos.
2. Make sure the key is in position 2 (gas gauge moves) when it tells you to turn the dashboard on.
#87
That's exactly what I got.
So my file on the ECU is saved correctly?
On the instructions I got from Velos it was shown that I should get a screen saying INFORMATION and some number codes underneath.
Ok, here are a few tips for now.
#89
SPONSOR
Plug it in to your PC and click the "Download from MyGenius" button. Just launch the client and you'll see it.
Save that file somewhere on your pc and email it to your tuner.
#90
I will do just that.
Thank You very much Jerry for your help.
Perfect customer service... although I'm not Your customer
#91
I just wanted to take the time to thank Jerry and this team for making themselves easily accessible, and for the follow-through to make sure that I / we're taken care of. Great service, for sure!
Now I need to readjust myself to get used to the noticeably angrier peak power when I punch the accelerator. The car is also noticeably more powerful in "C" mode as well
#92
Mercedes ML350, Mercedes C63 AMG
I was able to update the device succesfully yesterday, and after sending my info EC I got the tuned file back within the hour, super service!
Loaded the file this morning and although I already had a tune I can clearly feel the difference, gas respons is much better and I really feal the extra power.
#94
Mine still doesn't work. OE Tuning is working with Dimsport to resolve my issue.
I can upload only 1 tune to the Genius and then the upload button is greyed out. However, when I plug the Genius into my car to write the 1 tune, it's not there. Instead, it wants to re-identify my ECU. Then says ECU unknown, update needed. Which I've already updated my Genius. Errr!
#97
Went to a shop and clear cel code, it said "right 02 before cat".then uploaded v4 tune w/o2 off .No light for first 10 mile.After 2nd start drive few hundred feet LIGHT came back on.Thanks in advance .
#98
SPONSOR
We only turn off the 02 sensor AFTER the cat. The front ones are very important.
#99
