What is the difference between these 2 Xpipes
The shorter one will need to be welded in with 4 cuts to the stock pipes and the longer one will likely bolt in (and be more easily reversible) with one cut to the stock pipe. Are they both stainless steel? The longer one is likely $400-500 more expensive. Performance and sound should be similar.
Are they both made from the same diameter pipe?
