New Release: 2-Piece Brembo Big-Brake Kits for Mercedes C63 AMG from GMP Performance
Former Vendor of MBWorld
W211 E500 Estate
As a longtime authorized Brembo distributor, we are proud to announce the release of the Brembo GT(Gran Turismo) 2-piece big brake kits for the Mercedes C63 AMG. Brembo High Performance GT Systems are designed to give you the advanced technology behind Brembo racing systems without compromising the driveability and comfort features of an OE Brembo system. GT systems are revolutionary in their design and performance, and no other braking company has been able to offer this level of performance, range of configurations, and sheer number of applications. The GT systems exemplify Brembo's dominance as a world leader in high performance braking as an OEM supplier to a winning partner in motorsports.
We run Brembos on our daily driver Audi A5 and Golf R and are extremely happy with them on the street as well as on the track. We can get you set up with a complete GT kit, as well as high-temp race brake fluid and track pad options. Give us a call today for special pricing on a complete solution. Below are all the details for the kit's components, as well as links to the retail pricing.
The Mercedes C63 AMG Front Big Brake Kit uses a 6-Piston Monoblock 1N1 Caliper with a 405mm x 34mm 2-piece Rotor
Brembo engineers design each brake upgrade specifically for your vehicle and driving conditions. Optimum brake balance is achieved by combining Brembo's thorough knowledge of OEM braking systems and use of an unlimited range of caliper, piston, and disc combinations. Brembo brake upgrades are easy to install and designed to work seamlessly with your vehicle’s stock master cylinder, ABS, and traction control system.
Calipers
Most OE calipers are of a sliding design, with piston(s) only located on the inboard side of the disc. While this type of caliper is inexpensive to manufacture, it is generally extremely heavy, and inherently flexible under braking, which significantly degrades performance. Conversely, Brembo's calipers are a fixed radial or axial mount design with opposed pistons and constructed from aluminum alloy. Despite being much larger and many times stiffer than the sliding OE caliper, they are also much lighter which benefits overall vehicle dynamics.
The caliper body has been designed to be as light as possible while meeting stiffness criteria.
Calipers are available in the standard colors of black, silver, red and yellow. Dedicated track enthusiasts will want to stick with black as this is the most durable color.
Each Brembo system is delivered with preloaded calipers. Brembo calipers are equipped with unique pad retaining features and sequential piston bores in order to provide even pad wear and optimum performance. Quick Release Pad Retaining System: Incorporates anti-rattle feature (pictured) to eliminate noise and is designed for quick and easy pad changes.
Brake pads
Brake pads are selected vehicle specific for high performance.
The GT-R option
The Mercedes C63 AMG kit is available in the GT-R option. GT-R stands for Grand Turismo Race and monobloc calipers are machined entirely from billet with a nickel plated race finish to provide both the features and benefits of a racing brake system. This includes improved stiffness and thermo-mechanical resistance which is critical in high-performance applications.
GT-R's twin seal design provides race level performance without compromising the low maintenance aspects of a Brembo OE system. Ventilated stainless steel piston inserts are incorporated for heat rejection. The unique recessed dust seal design provides increased protection at elevated brake temperatures....another Brembo innovation.
Caliper Mounting Brackets
All Brembo caliper mounting brackets are designed vehicle and system specific. They are precision milled from superior quality billet materials to ensure a precise fit and meet the strength requirements of high performance driving conditions. Brembo brackets are also further analyzed and tested to ensure fatigue life.
Brembo caliper mounting brackets are also anodized to provide an attractive finish.
Each Brembo system includes all necessary hardware for ease of installation (please read instructions prior to installation).
Part numbers are clearly laser etched along with an unique serial number (S/N) for each part.
Pictured, are a few examples of axial and radial mount bracket designs.
2-Piece Disc
Superior metallurgy and exceptional engineering allow Brembo discs to exceed in the most demanding conditions. Their advanced cast iron alloy lasts longer than any disc in the high performance and racing market.
Brembo's properitary floating hardware system permits a specific amount of radial and axial float which allows the disc to grow independent from the bell, averting thermal distortion when subjected to extreme temperatures. It also preloads the disc assembly to prevent premature wear and eliminate noise during street use.
By manufacturing the center section out of precision milled billet aluminum, a great deal of weight can be saved in this key location. This reduces both unsprung and rotating weight which benefits handling, acceleration overall vehicle dynamics.
DISC THERMAL CAPACITY
A. Mass: The area located in the outer ring of the disc (shown in orange), dictates thermal capacity. This consists of annulus, width, diameter, air gap, and vane design.
B. Annulus: The area between two concentric circles. This dimension directly correlates to the friction surface area of the brake pad.
C. Disc Width: The overall thickness of the disc. Calipers are designed for a specific width.
D. Air Gap: The area located between the rotor plates surface is airgap. The amount of airgap is a crucial factor in channeling airflow.
E. Vane Design: Exclusive venting system that improves cooling capacity which increases resistance to brake fade.
Brake systems are designed to operate best within a prescribed temperature range. While modern high performance friction materials broaden this temperature range, it is critical that the brake disc in a system has adequate thermal capacity.
Thermal capacity, or heat storage capacity, is determined by how much weight or mass is located in the outer ring section of the disc. This is the area where the friction surface of the disc meets the internal vanes (orange colored area in the diagram shown). The more mass located in this area, the more thermal capacity a disc has.
CROSS DRILLED
• Cross drilled discs run at slightly lower temperatures due to added air flow through the surface of the disc where heat is generated.
• They are also highly effective in wet conditions and shedding debris from the disc to ensure a clean braking surface.
• Improve pad “bite”, improve wet weather performance, continuously refresh the brake pad
SLOTTED DISCS
• Slotted discs are recommended when using race pad materials or compounds. the vehicle is submitted to extreme braking duties such as towing or hauling heavy loads.
Type V and Type III discs are an option for enthusiasts seeking to improve rotor longevity.
AIRFLOW/COOLING
The curved vane disc is directional, and curved vane disc must be installed with the vanes running back from the inside to the outside diameters in the direction of rotation. Orienting the disc in the manner creates a centrifugal pump. The rotation of the disc causes air to be pumped from the center of the disc, through the vanes, and out through the outside diameter of the disc. This greatly enhances the disc’s ability to dissipate heat. Additionally, all of Brembo’s slotted discs are directional, regardless of the vane geometry. The discs should be installed such that the end of the slot nearest the outer edge of the disc contacts the pad first.
TECH NOTE: It is a popular misconception that the cross drill pattern determines the direction of rotation of the disc. In truth, for an internally vented drilled disc, the geometry of the vanes dictates the direction of rotation.
HARDWARE
The coupling between bell, rotor and bushing has been carefully studied by Brembo to prevent performance and comfort problems by defining the correct tolerances for all components and the proper tightening torque.
HOW IT WORKS
During braking, torque is transmitted from the disc to the bell through a fastener called a bobbin. This type of mounting system is designed to allow a specific amount of float in both radial and axial directions. This allows the disc to expand and contract under high temperature which reduces stress and increases longevity of the related components.
Brembo's unique anti-rattle disc hardware utilizes a spring fastener in order to slightly preload the assembly which eliminates the noise generally associated with floating discs.
The floating 2-piece anti-rattle disc hardware system, commonly used in high performance braking systems, was actually developed by Brembo back in the mid 90's.
This innovation was initially engineered exclusively for the McLaren F1 supercar which is why the hardware is often nicknamed the "McLaren" spring.
Stainless Steel Brake Lines
Each Brembo GT kit includes a set of stainless steel brake lines manufactured by Goodridge. Goodridge is the leading line supplier to OE manufacturers and championship winning race teams worldwide. With the tightest bend radius in the industry and the lowest rate of expansion, you can be assured that every inch of pressure from the pedal is transfered directly to where it counts - the caliper. Goodridge is the only brake hose system approved for use in every country in the world and it's guaranteed for life.
Goodridge High Performance Brakeline race-bred street brake lines are constructed from the finest quality hose, consisting of a PTFE inner hose covered by braided stainless steel. In addition to providing a more responsive and firm brake pedal by eliminating the “spongy” feel that often accompanies stock rubber brake lines, High Performance Brakelines are abrasion and corrosion resistant to stay good looking for a long time to come.
Some info about the brand behind the big brakes...
The Brembo High Performance (HP) Program is the direct result of winning over 200+ World Championships and decades of designing brake systems for the worlds top supercar manufacturers.
Brembo Dominated Motorsports: Formula 1, World Rally Championship (WRC), NASCAR, Champ Car World Series, Indy Racing League (IRL), American Le Mans Series (ALMS), Grand Am Rolex Sports Car Series, Speed World Challenge, and FIA GT Championship.
Brembo has a unique relationship working directly with automotive manufacturers to develop high performance braking solutions specifically for your vehicle. You can rest assured that every system designed by Brembo is specifically tuned for your vehicle like no other braking system on the market.
Brembo supplies over 30 automotive manufacturers including Acura, Aston Martin, Audi, BMW, Cadillac, Chrysler, Dodge, Ferrari, Ford, General Motors (GM), Honda, Infiniti, Jaguar, Jeep, Lamborghini, Land Rover, Lexus, Maserati, Mercedes-Benz, Mitsubishi, Nissan, Porsche, and Subaru.
Brembo uses its own foundries in the industrial process, whereby bringing a thorough knowledge of metallurgy to its design know-how which also creates further synergy in the optimization of the production cycle. The research and development phase is flanked by the testing phase which involves static, comfort and road testing and dynamic tests on test benches.
Brembo brakes are manufactured under quality and environmental ISO 9004 and ISO 14000 management standards which puts Brembo in a league of its own in high performance braking.
Calipers
Brake pads
The GT-R option
2-Piece Disc
CROSS DRILLED
SLOTTED DISCS
AIRFLOW/COOLING
HARDWARE
HOW IT WORKS
(a)'12 C63 P/P, LSD, 19" m/spoke,comfort pack. (b)Astra SRI.
Looks like a very comprehensive bit of gear.
Does this conversion include rears as well. The reason that I ask is that I would've thought that with increased braking efficiency on the front, you'd need a similar improvement on the rears to maintain the OE brake balance.
Cheers, Pickles.
Cheers, Pickles.
W211 E500 Estate
Cheers, Pickles.
Cheers, Pickles.
W211 E500 Estate
We've had a good number of Brembos installed at the shop lately. Will your car be the next to get a set? Whether installed here with us or at your local shop, you can't go wrong with some Brembo braking power.
How are these an improvement over the factory brake hardware?
Thanks.
Thanks.
^ this. We do have brembo braking system from stock (6 pistons F, 4 rear).
The calipers look similar. The only difference seems to be the discs and pads.
Am i right?
Am i right?
Those were my thoughts as well man. I realize the rear rotors are smallish on the stock setup but that hardware up front is pretty substantial.
W211 E500 Estate
This is probably the most popular question we get asked. I will break down the major components and explain the differences.
Brake Calipers - The Brembo caliper is forged and the factory isn't so it's lighter which means better cornering. The Brembo caliper has different internals to with stand higher temps for cars tracking their vehicles and this is important because the C63 is not a light car. The Brembo caliper can also take a larger brake disc for more stopping power and better looks Most Calipers are available in Black Red Silver and Yellow and custom colors are available for $275 per caliper all done by Brembo before they ship.
Brake Discs- The material that Brembo uses in their discs are superior in ever way. For clients driving their cars on the street they will notice much better stopping power because the brake discs are lighter than the factory. They last longer as well. The the outer brake discs rings are cheaper to replace than the factory brake discs when they are ready to be be replaced. You can get the Brembo discs are available in slotted pattern which are quiet enough for the street and have the higher thermal capacity to run 20 minute DE sessions to multiple hours of endurance racing.
Brake Lines - Each GT and GT-R Brembo big brake kit comes with Stainless Steal Brake lines which will not expand when your brake fluid heats up which helps against brake pedal loss which is a huge safety concern.
I hope this answered your question. If you have any others please don't hesitate to contact me directly.
Matthew@gmpperformance.com
Now, I definitely understand that the Brembo caliper that you are offering is forged whereas the factory caliper is not.
However, I was under the impression that the factory calipers are also Brembo calipers (they merely have AMG branding).
So, is it a situation in which the factory calipers are Brembos but a lesser model or is it a situation in which the factory calipers are not Brembo-made?
Thanks again.
2007 E63 w/P30 and Eurotech CF Diffuser
Well...
I know that the calipers on my E63, the CTS-V, and the 2014 Corvette use nearly identical Brembo Calipers.
I would be interested to know how the metallurgy is different on the aftermarket that the stock rotors. Which version of grey iron are they using?
1. Stainless brake lines... Understood.
2. Unknown disk material
3. Vanes correctly set for rotation, which is better than stock. I am pretty sure left and right have one part number.
4. Calipers, just can't see the advantage. Now put titanium pistons, and that would be a real upgrade on the calipers.
W211 E500 Estate
Well...
It explains every little item including in their kits.
http://www.racetechnologies.com/page3-42/GTSystems
W211 E500 Estate
This is really impossible to predict because everyone's driving habits and conditions are different but they will last longer than OEM. I have had their brakes in most of my cars in the past and can attest to this.
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
Um... nice sales pitch, but I am afraid you're mixing up your apples and pitchforks, not just oranges. Don't get me wrong, I am wholeheartedly agreeing with you that having better brakes is important (particularly for motorsport applications), but there is so much bull and incorrect information in your "explanation" above that it's laughable. At the very least, try to understand what the different bits and pieces do and what they contribute to the whole picture before you try to explain it to the rest of us. If you sell brake kits, the very least you can do is learn how they work and what the individual pieces do. Providing the wrong explanation is worse than not providing one at all.
BLKROKT (04-09-2019)
1 Post
C63 507, 911 Carrera, Range Rover, Disco
I saw this post a few months back...glad Diabolis called it out for what it is. I think the irritating thing about it is that you are mixing marketing jargon for street/race applications to get a sale. The C63 does in fact have the GT application or some Brembo derivative...there are no gains to be had here. Maybe SS lines but still that is debatable...the GT-R is an upgrade that does in fact have forged calipers as the GT are cast. The cost of those calipers is in the stratosphere...so not worth it unless you gut your C63 and plan to track it every weekend and even then you are talking minimal gains. On top of the fact you would likely need a dual master cylinder setup or larger master cylinder to get all that the calipers have to offer - its a system and needs to be matched as such. It does help with unpsrung weight and overall vehicle dynamics but to say it makes you "corner better" ???
So the irritability part - posting something like this to unsuspecting or unknowing owners - mixing the jargon is bad advertising. If someone bought the GT system thinking they are getting an upgrade it is basically like a caliper color swap - only. I would be pretty pissed if I took off the same calipers and replaced them with the same calipers - only to get a different color.
I drive a 911 on the track that has a Brembo BBK on it - but with that I had to upgrade the master cylinder, pedal cluster, lines etc to get the benefits...on the track brakes or more important than HP, so I am very familiar with the workings of them...piston bore, thermal reserves and capacity and brake torque are all things of interest to me.
In summary I am just saying you should be very specific in terms of what you are pitching, what we have (C63 wise) and what a true "upgrade" is.
The sls ceramics are 402mm/15.83" rotors and are a very tight squeeze on the factory 19" wheels. That wheel design looks like it could fit (no mega lip/deep dish 3 pc wheel etc..., but i can tell you most 19"s will not be able to fit them. Maybe try and find an sls with carbon ceramics to test fit? probably not going to be easy to find someone willing but just throwing it out there. Unless you are already experiencing brake fade i doubt you'll notice a difference, id personally go carbon ceramic over these anyways. Try to stay away from going 20" wheels as they dont have much for tire selection.
16" rotors are huge. It is extremely unlikely that they would fit under 19" wheels as that would leave less than 1.5" for the rim itself and the brake caliper. As roadtalonsi said, I seriously doubt that you'd notice a difference though. If you're tracking the car and experiencing brake fade, I'd start by putting in better brake fluid and maybe going to the BS rotors on the front instead.
1 Post
Not only are they huge they are heavy - and the worst kind of heavy is unsprung heavy, effects handling and acceleration.
The C63 is a lightweight car by most standards (with enormous brakes) - if you are overheating rotors on the track with upgraded pads/fluid...you may want to think about some performance driving tips...? You may be overdriving the car a bit.
Stock brakes and pads should be fine for some hot lapping at the track.
I didn't want to stir the pot, but you're 100% correct. The OEM brakes on the C63 are more than adequate even on a short, tight track. In my early days I have boiled the brake fluid on many cars, but it turned out it usually wasn't the car's fault, it was my driving. Some HPDE instruction and ATE Super Blue is all that was needed.
1 Post
Exactly - nobody wants to hear "learn to drive" and there is no real way to say it delicately, especially in a car forum...but there are instances time and time again where pro-drivers beat on these cars at the track in stock form and rave about brakes etc...lap after lap. No fade, no issues. I think the most recent was the R&T compare with the 507 and the RS-5.
If you are looking for a BBK for looks on the street - that's cool too, everybody has their thing, just be aware that adding monster brakes and bigger wheels really cut into your overall handling/performance levels.
This thread is old however I have a 2010 sl600. I am not sure what size the standard brakes were but they caught fire after 4 laps around SPA F1 circuit so I decided to go to the Brembo BBK route. The first thing I would say is that the 405mm front brakes we're considerably lighter than the standard smaller brakes. And the 380mm rear showed the same results.
I returned to SPA and also Silverstone GP and had consistent strong braking throughout the day. My tires couldn't cope but the brakes were awesome.
Just wanted to give some first hand knowledge of the upgrade as their seems to be very little around. By the way I have no doubt that the stock setup is more than sufficient for road use however they cannot cope with consistent braking loads from high speeds.
