C63 AMG (W204) 2008 - 2015
LSD for your Mercedes! Quaife and WaveTrac
Old 06-29-2015, 08:51 PM
  #401
///RAMS's Avatar
C63
Originally Posted by VividRacing
"Month Ending 36 hour sale!!! Aggressive pricing available to all forum members on all inventory!!! Don't miss out, contact me today!!! Sale ends as of close of business Tuesday 6/30."
Really?.
PM price LSD for C63 2009, Mexico. ZIP CODE 72810
Old 06-29-2015, 09:02 PM
  #402
Former Vendor of MBWorld
VividRacing's Avatar
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
PM on it's way!
Old 07-07-2015, 08:55 PM
  #403
traction
Old 07-16-2015, 08:27 PM
  #404
One of our most popular upgrade for the C63
Old 07-24-2015, 12:10 PM
  #405
***Friday Flash Sale*** One day only, save more than usual!
Old 07-29-2015, 05:18 PM
  #406
drawde's Avatar
2009 C63
pm price to 07307 please
Old 07-29-2015, 08:53 PM
  #407
Will PM Shortly
Old 08-05-2015, 07:47 PM
  #408
Get it.
Old 08-05-2015, 10:15 PM
  #409
leungsta's Avatar
C63 AMG Coupe, BMW 335xi Frozen Silver
Make another special and I might consider
Can you provide pricing for both waver tax and quaife please shipped to 12919? Thanks
Old 08-06-2015, 12:10 PM
  #410
Will PM shortly.
Old 08-18-2015, 02:03 PM
  #411
Grab Grab Grab
Old 08-18-2015, 08:13 PM
  #412
avery.whss's Avatar
S550 on order
i have the wavetrac...car pulls faster for sure
I'd consider getting wavetrac before a tune or any other mod actually..factory LSD feels sloppy as hell compared to wavetrac, and well if you have no LSD then dont think twice
Old 08-18-2015, 09:52 PM
  #413
PlacidBoi's Avatar
C63 AMG Coupe
Price shipped to 91801
Thanks!
Old 08-19-2015, 04:19 AM
  #414
Missionary's Avatar
C63 2012 M156
I have seen it asked but not answered as yet. Is there a coding option for the LSD?
Old 08-19-2015, 08:15 AM
  #415
Mort's Avatar
Option code 471 Mechanical Locking Differential.
Old 08-19-2015, 12:07 PM
  #416
Thanks for the support!
Old 08-19-2015, 03:37 PM
  #417
Missionary's Avatar
C63 2012 M156
Thanks Mort, do we know if FDOK/VeDOK data base
(SCN) access is required to activate this option? Is 471 activation a nice to have or is it required for ESC to work properly post retrofit?
Old 08-19-2015, 07:19 PM
  #418
Mort's Avatar
I am going to say that ESC is independent of rear differential and no coding is required if you add a mechanical LSD.
Old 08-19-2015, 09:11 PM
  #419
Missionary's Avatar
C63 2012 M156
OK, I spoke to an installer here that have done a number of Quaifes and they said that they do activate the LSD option when they retro fit. Anyone confirm this when they had them fitted? It would be good to xcheck this.
Old 08-20-2015, 04:10 AM
  #420
Missionary's Avatar
C63 2012 M156
I spoke to a couple of Weistec dealers today in Australia including the tech that has built the fastest N/A and forced C63s there. He had done over 80 LSD retrofits as well and tracked on both the Quaifes and WaveTracs.
It would appear that the machining required by the WaveTrac on the housing is just a quick burst on the linnisher when they have every thing apart. This is not a running clearance but a fitting clearance issue. So no biggie.
The coding to activate 471 (LSD) does not require SCN and does reduce the sensitivity of the traction control and helps stop brakes being applied on launch.
His preference between the Quaife and the WaveTrac was for the Quaife. Slightly smoother and a little more depandable that it was always going to give you two wheels so a little tighter. He said both were good and his focus was very much at the sharp end of the game.
Old 08-20-2015, 04:43 AM
  #421
Mazspeed's Avatar
C63 amg Custom 67 Camaro GLK 350 4matic 2017 AMG GTS
Any special,pricing on the wavetrac? Also need pricing to 95032. Thanks.
Old 08-20-2015, 12:27 PM
  #422
Will PM shortly.
Old 08-25-2015, 08:37 PM
  #423
Traction
Old 08-26-2015, 08:44 PM
  #424
Bigtickets's Avatar
E55K, Black on Black. C63, Black on Black. SRT-10 NightRunner 363of400
Could you shoot me a price on the Quaife shipped to 29464.
Also, what's the deal? Does the 471 code need to be activated for optimal performance?
Old 08-27-2015, 10:50 AM
  #425
avery.whss's Avatar
S550 on order
theres no codes needed to be activated with the diff, all the ESP is done through the braking system if a mechanic tells you theres codes needed to be activated their a lying pos ..take it to an actual diff shop not just some general mechanic
seeing they have to shave a tiny bit off to make the diff fit, its a job i would not cheap out on, it would really suck for some mechanic to shave off a lil more then intended then youre really screwed
Quick Reply: LSD for your Mercedes! Quaife and WaveTrac
