C63 AMG (W204) 2008 - 2015
window trim wrap
Old 01-13-2013, 03:56 PM
Aresh's Avatar
C63
window trim wrap
Anyone in long island NY experienced with wrapping window trim? Whats your cost? Or any shops near huntington?
Old 01-13-2013, 05:30 PM
Rsquad911's Avatar
97 Porsche GT2 Wide Bodied Cabrio, Mercedes G500
Usually costs $120-150
Old 01-13-2013, 05:51 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
It's a sample DIY. Buy some pry tool to remove the trim and wrap them with some 3M film. Should cost you less than 50$ i guess. And a little bit of patience as well. Good luck
Old 01-13-2013, 10:14 PM
Aresh's Avatar
C63
thanks i would try this except the trim looks like ti wont pop off as other trims. Also id rather pay a little to have a pro do it or someone with experience.
Old 01-13-2013, 11:27 PM
BerBer63's Avatar
2009 C63
Had pros do it any they scratched my car with razor blade installing it rather than prying pieces off first like I did on the redo....
Old 01-13-2013, 11:30 PM
Aresh's Avatar
C63
yea i think ill plastidip mine
Old 01-13-2013, 11:46 PM
Killswitch747's Avatar
C63
Take my advice and do not do plasti dip. I used the black with the glossifer and it came out funky. Not glossy enough and rough texture. Remove all the trim which is easy, but be careful with the plastic trim parts as they can crack easily. Stick with vinyl. should cost around 70-80
Old 01-13-2013, 11:49 PM
Aresh's Avatar
C63
wow thanks for the heads up, i was almost def going to do plastidip but not now. Only issue is i dont know hoew to remove trim on the coupe
Old 01-13-2013, 11:54 PM
C63
Not sure on how to remove it on a coupe, but here is how its done on a sedan. Should be same?
Old 01-14-2013, 12:02 AM
Aresh's Avatar
C63
thanks for the link, sedan looks easy, the coupe is much different, at least the upper part.
Old 01-14-2013, 12:22 AM
abcut973's Avatar
I think it should be the same for the coupe. Lower trim needs to be lifted up. Looking at coupe pictures the upper trim should be one piece going front to back like the sedan hold by plastic clips. Some gentle pry work required.
Old 01-14-2013, 12:28 AM
Aresh's Avatar
C63
yea the bottom is the same, the upper trim extends into the door, so that bit is weird. ill have to take a pic
Old 01-14-2013, 12:48 AM
abcut973's Avatar
I see what you are saying. The trim sits on the upper front door.
So could be the same thing as the lower trim. You need to remove it from its track i guess.
Old 01-14-2013, 06:32 PM
vinh512's Avatar
2006 ML350
Not that close but there is a shop called Carzskin Vehicle Wrap in philly they did a great job on mine. It was $125.
Quick Reply: window trim wrap
