C63 AMG (W204) 2008 - 2015
What is the recommended tune?
Old 01-25-2013, 01:17 AM
tomespo's Avatar
Huracan STO
You read so many different reviews and its just making this decision that much harder lol. Of say the three I hear the most about are MHP,OE and Eurocharged. Plan on getting a tune right away when I receive the car. (Removing resonators and cats, adding an x pipe) but not gettin headers right away. Of course I want a tune that will make the most power, and then within a few months I'm sure ill be adding headers so I need a company that has a tune for a c63 with no cats and also one that has tuned on cars with headers so I can upgrade the tune when I install headers.
Old 01-25-2013, 03:08 AM
Faris63's Avatar
'13 CLS63 PP
I would go with OE tuning with their handheld tuning programmes which make it easier for you to get updated tunes and upload them to your car I think it come with 4 maps which is really nice
Old 01-25-2013, 04:29 AM
Merc63's Avatar
C63 AMG
DO YOUR RESEARCH.
You will find the way.
Old 01-25-2013, 05:29 AM
olszowa12's Avatar
'08 C63 Estate
I'd say stick with the stock factory setup for at least a month, test the car and only then get the tune.
Otherwise you won't see the difference.
I got the Velos Deisgnwerks tune (+35WHP on dyno) and am extremely happy because above 5000rpms the car is an animal.
And if You are planning to get headers as well, check which company offers free retunes
Matt
Old 01-25-2013, 09:33 AM
SaintC63's Avatar
2013 C63 AMG
Also seeking a tune
I have been monitoring the forums over the past month so I am in the same boat here. I don't plan on getting a tune until I do the 1000 mile break in that is recommended by MB. I don't want to do some huge like DAD's but I also want to go for monster sound with some added HP.
Also, when companies advertise more efficiency with their tunes, what are they implying? I was under the impression that if your car is more fuel efficient that you will have less power.
I apologize in advance for the ignorance but I am fairly new to modding, and I trust advice in this forum more so than the average rice burner shops you see around town.
Thanks!
Old 01-25-2013, 10:07 AM
SPONSOR
loungn14's Avatar
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
We can easily help you with that when your ready. We offer safe and proven power, and can easily CUSTOM tune you as well when needed. We can either sell you a remote handheld flasher or you can stop in at one of our locations or our dealers around the world.
Thanks!
With just the tune the sound will be awesome. We open the throttle body more and some people have said it sounds like they added and exhaust!
The cars run extremely rich (lots of fuel) from the factory, and most tuners like us remove some of that fuel. You will actually make more power when doing that (along with other things) as well as gain mpg in the process!
Just like was previously mentioned, do your homework on your tuner of choice. Make sure they have been around for a while and know the platform, have a ton of happy customer references, and are available if you have any issues during the process or post tune!
Old 01-25-2013, 10:22 AM
AMG9's Avatar
2012 C63 coupe P31/LSD
the air fuel ratio is leaner than stock. Less fuel is being sprayed by the injectors per volume of air. But I didnt notice any better gas mileage. This is a minute difference. In fact you car will probably run a bit hot, mine does. A rich air/fuel ratio cools the pistons bec the fuel being sprayed into the intake tract has a cooling effect on the air in going in. But too rich Losses power. The key is to get just the right ratio. According to OE, they aim for Full load fuel 12.5-12.7 (stock is 10.8-11.2).
Another theory is that if you make more power at a given rpm, you will use less throttle to maintain the same speed while cruising bec you are making more power. This is also a minute difference IMO. Makes more sense in turbos bec the tune does really give you a lot more power at lower rpms on a turbo engine.
Old 01-25-2013, 02:08 PM
johnnyblaze's Avatar
CLS63S
I'll name off some of the tuners for you so you can search and then research on your own.
The big ones,
Eurocharged
MHP
OETuning
Weistec
Renntech
Kleeman
Other tuners with good reputations,
Buckhead Imports (BIP) (big in the E55 platforms, but have dyno proven 63 platform tunes)
Velos Designworks
LogicLab Tuning (newer but hasnt had a negative review)
Tuners Im not sure about...
Powerchip
I went with OETuning because they are local and come highly recommended by my mechanic (Serge@BenzWorks). My advice to anyone is to get a custom dyno tune done. Box tunes are good but every car is slightly different than the next.
Old 01-25-2013, 02:13 PM
JumpinJim's Avatar
SL63
Bottom line is they're all basically the same and will perform the same. Talk to a few tuners and pick the one you're most comfortable with.
Old 01-25-2013, 02:32 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
I don't know if Powerchip is still in business. I've tried all sorts of avenues to try to see if my tune is locked or not. Apparently, the only way for me to find out is by trying to write over it...which means I would have to buy a handheld tuner or go somewhere and see as it goes.
Old 01-25-2013, 02:44 PM
propain's Avatar
See Sig
OE or MHP.
Proven results.
Old 01-25-2013, 03:15 PM
2012C63AMG's Avatar
2012 C63 AMG
I recommend going with a big name company. You are risking a very expensive motor if you go with some idiot who is just reselling copies of tunes from other people.
I personally have Kleeman tune on my car, Corey took great care of me. The only disadvantage is they do not offer a handheld tuner. But at the time I bought the tune this wasn't available from anyone.
I dont have OE tuning, but I would recommend them as they have been around for a long time here now with no issues.
I would run away form MHP, they have been banned from here. And people have had bad experiences including myself. (not a product issue for me but an honesty issues and putting my ECU at risk for being stolen)
Basically you want to find a shop that can afford to replace your car if they mess it up. I know I can go after the tuner I used legally since they are big and established and have assets.
You have to watch out as several tuners are just running it out of their house, some of which you couldnt even sell the house and buy an AMG...Dont be fooled by a nice site and a few pictures of cars and a few customer reviews, they can be planted.
Old 01-25-2013, 03:46 PM
emericr's Avatar
2021 Porsche TTS
As you can see, everyone has their own opinion. If you go with a reputable tuner named above, you should not have a problem.
Some tuners will push their tune more than others and therefore make a bit more power.
I went with Jerry (Eurocharged) due to the his customer care and the fact that he travels quite a bit and was able to get a custom tune in Miami after I got a regular tune.
Good luck and enjoy.
Old 01-25-2013, 06:37 PM
SB...C63's Avatar
C63
Eurocharged for me.
Alex at Fineline in Miami is a great guy.
The handheld tuner is a big plus, you can at anytime revert to original tune when you go to MB for service. Plus there always working on new custom updates for you. Super happy with them. Best mod ever.
https://mbworld.org/forums/florida/4...ler-miami.html
Old 01-25-2013, 06:42 PM
Guilty's Avatar
'16 C63-S
Which track is that?!
Old 01-25-2013, 06:48 PM
SB...C63's Avatar
C63
Homestead.....
Old 01-25-2013, 06:52 PM
2012C63AMG's Avatar
2012 C63 AMG
The big 3,
Eurocharged
MHP
OETuning
Velos Designworks
LogicLab Tuning
Kleeman
Renntech (expensive but proven results)
Powerchip
Sorry saw your post... and had to chime in on it.
The big 2 companies are Renntech and Kleeman they have been tuning Merc's far longer than any of the others. Renntech has a reputation for being $$$, but from what I was told the company uses AMG techs/connections.
I dont get how you can say "good reputation" for some of them posted.
1. Logici lab tuning is brand new, we have yet to see any dyno results or hear any customer feed back.... They have 0 reputation IMO. If they are good then thats one heck of a price and others will have to drop down.
2. Velos got off to a bad start here by posting Dyno graphs which were misleading, which was cleared up in another debate months ago. (Posting graphs that showed different correction which inflated HP numbers). I have yet to see an unhappy customer (The C63 BS guy doesnt count as we couldnt get a clear answer from him, you can search and find this in the debate over inflated numbers)
3. MHP is not a big 3.
4. Buckhead Imports I have been here lurking before I joined for 3 years. I have never heard of this company or seen it mentioned here once.
Please folks add to this, I would like to see a sticky of tuners, so folks can post feedback of the companies either positive or negative.
Please if you see anything I wrote disagree or agree with it, but lets keep it fact based. Also here on MBW I am sure I could become a sponsor if I paid the dues, lets not forget the past sponsors who have been banned here.
Old 01-25-2013, 07:10 PM
olszowa12's Avatar
'08 C63 Estate
I went with Velos and am very happy with the results.
+35RHWP is good enough for me
Kleeman seems a little outdated to me. The last time I heard about them was when they screwed Weistec over with their "own" supercharger.
And Renntech is better because "you were told that they have AMG connections"?
There are so many threads about different reviews on tunes that you can do a thorough research in a few minutes.
I've been here for a while as well and all I can say is that I haven't heard a bad review on OE Tuning, Eurocharged, Velos (except for Kaiba's C63 BS), or Kleeman.
I do agree that no one posted any reviews or private dynos of BI Performance or Logic Lab.
As for MHP, there are those who love it and those who don't. The fastest C63 here (Dads) runs MHP hardware and software.
Old 01-25-2013, 07:35 PM
CLS63S
When I say big 3, i mean majority of the people that frequent these boards are running their tune. I should have been more clear.
3. Since I switched to a C63 last year from an E55 they were one of the first mentioned tuners(MHP) when I read up and searched the forums.
4. Buckhead Imports is bigger in the E55 than in the C63, my apologies, I should have been more clear. In the W211 AMG forum they get a lot of love, but not much here but I have seen dynos of their C63 and other of the 63 platforms. I have yet to read a negative review of them.
Here is a more recent thread of theirs and a E63 dyno is included in the thread.
https://mbworld.org/forums/w211-amg/...ning-sale.html
These choices are of a personal log of my own, I'm not saying these are the ONLY companies. Maybe we should create a sticky for tuners without starting a tuner war for everyone to read.
Old 01-25-2013, 07:41 PM
Guilty's Avatar
'16 C63-S
No one mentions Weistec? lol
CLS63S
Let me add them in... updated my list LOL.
changed some verbage :P
Old 01-25-2013, 10:38 PM
Higgs Boson's Avatar
2020 AMG GTR
I would not get a tune from anyone who claims you will gain mpg by leaning out your car in open loop..... you car gets leaned out in open loop which is only at wide open throttle. your car runs at a stoichiometric ratio at part throttle which is not changed with a tune. your oxygen sensors and maf, etc all keep the af ratio at stoich until you go wot.....any tuner that doesn't know that doesn't know what they are doing.
maybe you aren't the tuner, just the Internet salesperson, hype creator, that is fine but I suggest you figure out what it is you guys are really doing before you post it online.
Old 01-26-2013, 01:34 PM
rlh23's Avatar
2004 SL55
This might get good...
Old 01-26-2013, 02:41 PM
tuptus's Avatar
audi>mercedes-benz
Speedriven
Old 02-04-2013, 02:13 PM
rags260z's Avatar
2011 C63, '78 LS1 280Z, '71 240Zt, '87 Grand National, '01 F150
Stoichiometric at part throttle? Under all circumstances? Learn something new everyday. If the factory tune does try to keep the ratio stoichiometric at everything besides WOT, I would think there is a ton of room for improvement. Forgive me if this has been discussed before but I'm new to tuning these cars, spending all of my time with American LSx platforms and Electromotive standalone on boosted older Japanese six cylinders.
Joe
Quick Reply: What is the recommended tune?
