Need help in Wheel size
W204
Hi Guys,
Sorry if somebody would tell me that I have to use the search tab, but I did and I couldn't find what I want.
Anyway now I am using BBS CHR with this following size:
At the front 19" 8.5 wide ET 40 with 235 35 19 tires
At the back 19" 9.5 wide ET 45 with 264 30 19 tires
Now my question is if I want to get different wheel with this following size:
At the front 19" 8.5 wide with 245 35 19
At the front 19" 10 wide with 275 30 19
What are the best offsets that I could go with?
I want to have the same looks as what i have now.
meaning how far the end of the wheel to the tip of the fender, because i don't have any rubbing problem now.
PS: I am not lowering car. This car is low enough for me.
Thank you very much for your support
This is how my car looks for now
To have the same "look" that you have now, you can go with the same offset in the front or maybe even add a couple mm to go +42...on the rear, for the same look, it would be a +51 offset, but you risk rubbing a bit with a 275 depending on the tire brand. I am running a 10" wheel with a 275/30/10 with a 54 offset on the stock suspension and I do not rub but it is close to both the inner wheel well and the fender...I think without making any modifications, a 275 is the widest tire that will fit in the space provided by MB...and even then, it depends on tire brand and getting the offset perfect.
For the rear on a 10" wide and a 275, you will need to stick as close as possible to stock (ET54). Only move within a few millimeters. Why don't you just fit the 265?
