C63 AMG (W204)2-piece light weight rotor (save now $$$$$)
Former Vendor of MBWorld
Hi everyone, we are now offering our newly designed and development convergent vanes open slot rotors for some of the Mercedes applications. These rotors are the sport tuned type, best and latest technology in the market today, superior to oem and competitors, application are for the 2007+ C63 (W204). These rotors are the best in the business it will outperform any high end two-piece rotor out there and the positive feedback about its performance we have been is enormous. These rotors are exclusively designed and engineered to prevent from cracking and warping suitable for any kind of driving condition. The mass reduction on the front is 5.0 lbs. the rear is 5.25 lbs. by far the lightest rotor out there for any Mb C63 application, lighter rotors means better performance at the wheels and don't be surprise, if your gain extra 10 to 25 whopping horsepower after installing these rotors with your (g-ride). This is your chance to gain those hp back that was lost with the heavy oem and competitors rotors plus gain more miles per gallons. It is proven that a lighter rotor can increase horsepower at the wheels check the dyno testing.
Front rotor weight Comparison
OEM Rotor 29 lbs.
RB 2 Piece 24 lbs.
Weight Savings: 5 lbs.
Rear rotor weight Comparison
One-piece 21.5 lbs.
RB 2-piece 16.25 lbs.
Weight Savings: 5.25 lbs.
Total weight saving: 20.5 lbs.
2007+ C63 (W204) FRONT 2-PIECE ROTOR
2007+ C63 (W204) REAR 2-PIECE ROTOR
RacingBrake 2 Piece Rotor Review!
These rotors are engineered to be the best stock replacement two-piece rotors on the performance market. These rotors are direct bolt-on, easy to install, no additional hardware needed, and an excellent upgrade for both streets and track. Not only will the rotors last 3, times or more longer than competitions' two-piece rotors, they can deliver consistent brake torque under extreme heat, session after session. When it comes to replacement, the operating cost over the time will be lower than one-piece rotors.
RB offers a complete satisfaction guarantee to you and other MB enthusiasts; if you don't agree that they are the best two-piece rotors in value, look and performance your money can buy just return them for a refund.
• Has the advantages of both drilled & slotted rotors.
• Allows the disc to expand and contract and prevents the disc from cracking or warping.
• Increasing cooling area and retains more friction surface.
• Slots relieves thermal stress.
• Slots are self cleaning and the pad build up will not clog the slots and are exhausted via the rotor edge keeping the disc surface clean.
• Reduces brake pad dust buildup and keeps the wheel clean through vacuum effect.
Rotor Material: Racing Formula Alloyed Gray Iron & Heat treated
Machining: Straight Slot
Surface: EDP Coating w/cross cut grinding on friction surface.
OEM Rotor 29 lbs.
RB 2 Piece 24 lbs.
One-piece 21.5 lbs.
1 Post
2010 C63 AMG
Is there actually anyone using these with racing compound pads to support the data generated by an Engineer and Draftsman with an art degree?
Sorry to seem skeptical but I have seen a lot of slotted this and drilled that, all advertising better performance, lighter weight and when it comes down to it, its all just advertising hype followed by another set of boat anchors taking up space in the storage room of what didn't work.
Price please for 2010 c63 front and rear to Australia Victoria 3011
PM Sent.
We only offer open slot for C63.
For those of you interested in purchasing front and rear rotors we offer a special package that includes our quiet low dust street pads at a discounted package price.
Link to C63 brake package: http://www.racingbrake.com/ProductDe...C63-P&CartID=1
2010 C63 P31 AMG
PM Sent.
