C63 AMG (W204) 2008 - 2015
Campionishop: Introducing the NEW Forgestar CF5V!
Old 03-01-2013, 11:31 AM
Former Vendor of MBWorld
CampioniShop's Avatar
CAMPIONISHOP presents the new Forgestar CF5V wheels. It is that time of the year to prepare for the upcoming track season, get in on this opportunity to get great wheels at unbelievable pricing! We are one of Forgestar's biggest dealer and as such offer year-round specials on all their products!
About Mercedes Benz Forgestar Performance Wheels:
Introducing the World's 1st 1 piece lightweight flow formed wheel lineup.
  • 1 piece flow formed wheels
  • Lightweight
  • Clears big brake kit
  • Great range of offsets
  • Same Technology Used on Formula 1 and Indy Cars
  • Standard finishes: Gloss black, Matte black, Textured black, Silver, Gunmetal, Textured Gunmetal, Matte Gunmetal, Frost white, Race gold
  • Custom made: 6-8 weeks lead time for production
o All Forgestar wheels are provided with metal hub centric rings in order to mount the wheels.
FLOW-FORMING
Forgestar's flowforming process is a unique solution to a common problem – how to make a wheel both light and strong.
This specialized process begins with a low pressure type of casting and uses a special machine that spins the initial casting, heats the outer portion of the casting and then uses steel rollers pressed against the rim area to pull the rim to its final width and shape. The combination of the heat, pressure and spinning create a rim area with the strength similar to a forged wheel. During Flow Forming, the pressure applied to the cast rim actually changes its mechanical properties, so its strength and impact values become similar to those of a forged rim. That translates to up to 15% less weight when compared to a standard cast wheel. The resulting grain structure within the alloy of the wheel is linear, flowing in a single direction.
This grain structure pattern, combined with the exceptional quality of casting required for the process, gives the rim area of the wheel huge mechanical strength, and elongation. As a result of these mechanical characteristics, Forgestar is able to reduce the thickness of the rim area resulting in reduced weight, without compromising strength and resistance to impact.
The CF5V is only available in 19" Fitment!
Offset is built to order.
There is a 6-8 week lead time for custom production.
CF5V Pricing:
$1560 Plus Shipping ($150 to the U.S. and $250 to Canada)
Sizes and Offsets:
19x8.5 ET+10 to ET+50
19x9 ET+12 to ET+56
19x9.5 ET-2 to ET+42
19x10 ET+4 to ET+48
19x11 ET+17 to ET+61
Standard Finishes:
Custom Finishes (available at additional cost)
Old 03-01-2013, 04:07 PM
bobbyo's Avatar
c63
pricing
what is the weight? for 2011 c63 not lowered? Most aggressive offset with out rubbing, Color of car is Palladium Silver, what color do you recommend? do you guys do brushed tinted clear?
Old 03-01-2013, 04:08 PM
The 19x8.5 wheel only weighs 19.8 lbs! That is the only weight info I have at this time. I will send you a PM.
Old 03-01-2013, 08:22 PM
SaintC63's Avatar
2013 C63 AMG
Any wide options?
Old 03-01-2013, 09:25 PM
Originally Posted by SaintC63
Any wide options?
Yes sir! We offer these sizes and offsets:
19x9 ET+12 to ET+56
19x10 ET+4 to ET+48
Old 03-02-2013, 09:58 AM
BUMP
Old 03-03-2013, 02:07 PM
BUMP
Old 03-04-2013, 12:18 PM
BUMP
Quick Reply: Campionishop: Introducing the NEW Forgestar CF5V!
