C63 AMG (W204) 2008 - 2015
Transmission service = less aggressive shifting?
Old 03-09-2013, 08:53 AM
e55 addict's Avatar
check sig ;)
Got my trans serviced on my 09 C63 Sedan at my friends garage. They ordered everything directly from MB. They used the Alldata procedures and did a TCU reset. Now while the shifting is way smoother it lost the crispness in the shifts I have grown to love. Will just driving it aggressively help the TCU relearn my driving style or is it supposed to be that smooth and I just didnt realize the fluid was shot.
Old 03-09-2013, 09:54 AM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
If there wasn't anything "wrong" with the transmission fluid before the service, then it's just the need to relearn your driving habits.
Old 03-09-2013, 11:23 AM
Merc63's Avatar
C63 AMG
I don't recall noticing a difference after doing my own tranny flush.
Not sure if we reset the tcu though.
Try manual mode, see if its the same still.
Old 03-09-2013, 12:28 PM
callmiro's Avatar
2016 C63 S
After a TCU reset, you have to drive it like you stole it. This way the TCU will learn to be aggressive and your shifts will be more aggressive.
Old 03-09-2013, 01:58 PM
C-63AMG's Avatar
C63 AMG
If someone does the TCU reset, is a tune still on the car?
Old 03-09-2013, 02:40 PM
Yes. The tune is in the ECU. You can reset the TCU by following the instructions here, #10:
https://mbworld.org/forums/showthread.php?t=249371
Old 03-09-2013, 02:59 PM
C-63AMG's Avatar
C63 AMG
Thanks CoolBD,
So I can do the TCU reset, drive the beast like it's stollen by someone who has nothing to lose and get more aggressive shifts etc?
Old 03-09-2013, 03:26 PM
callmiro's Avatar
2016 C63 S
Originally Posted by C-63AMG
Thanks CoolBD,
Yah man...that's the idea...
The tranny is adaptive, so if it was driven conservatively in its early miles, the tranny adapted to that conservative style. If you reset it, it will re-learn based on how aggresively you drive it after the reset.
Old 03-09-2013, 03:28 PM
I asked the question months ago, but no one seems to know how long the learning process is or if it cycles as you drive more.
Old 03-09-2013, 03:31 PM
Even Money's Avatar
'15 VW GTI
I suspect that just as it will adapt to a more aggressive driving style, it will adapt to a more easy driving style as well. So, you have to drive it consistently the way that you want it to perform.
Old 03-09-2013, 03:35 PM
callmiro's Avatar
2016 C63 S
I think the logic is that your first couple of hard, hammer down, pulls should be as aggressive as possible for the tranny to pick it up....if you let off during maximum pulls, then the tranny will adapt to that and not shift as hard or hold as long....
So re-set, and then find some open stretches and open the gates of hell.
C-63AMG's Avatar
C63 AMG
Am gonna do this and rape this ***** like it's the last day of the world.
Old 03-09-2013, 03:45 PM
C-63AMG's Avatar
C63 AMG
https://mbworld.org/forums/c-class-w204/249371-w204-secrets-thread.html
Thanks - just read. How do we know if the TCU reset or not?
10) Steps to Reset the TCU. Resetting the TCU will reset transmission to factory shift points and the car will 'relearn' your driving style.
(1.) Turn the ignition key to the on (not start) position.
(2.) Press the gas pedal to the floor and hold for five seconds.
(3.) Turn the key to the "off" position (don't remove the key), then release the gas pedal.
(4.) Wait at least two minutes for TCU to reset.
Old 03-09-2013, 03:49 PM
callmiro's Avatar
2016 C63 S
I just disconnected my battery overnight
Old 03-09-2013, 03:51 PM
C-63AMG's Avatar
C63 AMG
Sure fire method bud?
So I just need to disconnect either the + or - and reconnect 10 hours later and the TCU will be reset?
Old 03-09-2013, 03:53 PM
callmiro's Avatar
2016 C63 S
Yah....you don't have to wait that long....i've heard others do it for anywhere from 10-30 minutes....
I just did it overnight while the car was parked
Old 03-09-2013, 04:05 PM
I've noticed that the gear changes adapt every so often, but I don't know what the time period is. I wish I could get a straight answer. If I track the car, I want to know how long it takes to "normalize."
Old 03-09-2013, 06:23 PM
e55 addict's Avatar
check sig ;)
Been driving the hell out of it and the shifting has gotten noticably quicker and more aggressive. Shifts fast and holds the gear like it used to
Old 03-09-2013, 06:32 PM
callmiro's Avatar
2016 C63 S
Awesome!
I feel sorry for any M3's in your area!
Quick Reply: Transmission service = less aggressive shifting?
