C63 AMG (W204) 2008 - 2015
Help.....P2187
Old 03-11-2013, 11:35 AM
Osgee's Avatar
W211 E55 AMG & W163 ML270
Help.....P2187
I got an intermitant cell light with the following code and message:
* 0745 - Self-adaption of mixture formulation for enrichment at idle for the right cylinder bank is above the permissible limit (P2187)
Any idea on the cause ? Is this the normal P2187 message ?
Old 03-12-2013, 01:11 PM
Osgee's Avatar
Found broken up airfilters that were both soaked in oil ? These were dry foam air filters so I dont know where this oil has cone from any ideas??
Old 03-12-2013, 01:42 PM
j bro's Avatar
2009 C63 ///Amg
I had this code too would like to know what it is from?
Anyone else had experience with this code?
Old 03-12-2013, 02:00 PM
Osgee's Avatar
Have you checked your filters ?
Old 03-12-2013, 05:00 PM
Merc63's Avatar
C63 AMG
How are the MAFs if your filters are soaked with oil?
The filters broke apart??
Define "soaked in oil"
Old 03-12-2013, 05:16 PM
Osgee's Avatar
The mafs had oil spray on them, there was a small pool of oil in the filter housing more on the right side (uk drivers side ) than the left and the foam air filters were covered in it, to the point you could actually see the oil on the filter, as if over time the oil had been seeping through.
The filters had broke apart at the seems luckily all parts ere accounted for and none got sucked into the intake,
The oil looked like clean engine oil, very strange as to where this has come from, the car isnt burning oil any more than the norm and the air filters were dry foam filters by piper cross,
Ive taken them out binned the filters and cleaned all the housing abd MAFs ... awating arrival of stock filters tomorrow to use
Old 03-12-2013, 07:01 PM
Merc63's Avatar
C63 AMG
Your right bank is running too rich on idle start up. Could be MAF not reading properly.
Curious why you have oil in the air box....
