C63 AMG (W204) 2008 - 2015
Drive mode D1 vs M
Old 03-28-2013, 01:00 AM
myfault's Avatar
c230
Drive mode D1 vs M
When u are stopped in S mode and hit left paddle it goes to D1 and you manually shift. What's the difference between that and regular M?
I have a 2009 c63
Thanks!
Old 03-28-2013, 01:05 AM
natman316's Avatar
2012 C63 2015 C300 sport
D1 is kind of like in those old auto matics where its PRND321. for example, highest gear in D3 it can go is 3, but it will still use 1-2-3 automatically
Old 03-28-2013, 01:14 AM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
I think M stays in gear until you shift. S/manual shifts automatically at redline, right?
Old 03-28-2013, 02:20 AM
vmx128's Avatar
2011 C63 P31
That is not correct. See below.
Yes, you will hit the rev limiter in M, which will end up killing your throttle for a few moments. In some cars (like my Lotus), the rev limiter bounces at the redline so it keeps you going, but in our cars, the throttle is totally killed for what seems like an eternity. Not a very pleasant feeling as it throws you forward. Also, because of the laggy shift response, it is hard to shift at redline in M as you have to take the lag into account and shift before you reach redline. Some practice is needed to get the shifts right.
The Sx and Cx(S1,C1 etc.) modes shift into the next gear precisely at redline. So if you are in S1, you will shift to the second gear at redline. I think in the old cars with D1,D3, etc, you stayed within 1 and that gear as CoolBDPhenom mentioned above.
Old 03-28-2013, 02:28 AM
So if Sx shifts at redline, what's the difference between Sx and Cx? I haven't played around with those settings.
Old 03-28-2013, 02:39 AM
natman316's Avatar
huh?? I'm pretty sure if you are in S5 or c5, it will use gears 1-5 normally it just wont shift above 5. Theres no way it will rev all the way to redline even in part throttle...at least thats how it is in my 2012. S+ is supposed to shift at redline all the time if you floor it or drive aggressive, but under light throttle it still shifts normally (I dont use s+ much but I've def seen it shift at like 3-4k)
Old 03-28-2013, 12:58 PM
myfault's Avatar
c230
so at the drag strip would it be better to launch in regular S mode, or D1 if don't want to have to manually shift?
Old 03-28-2013, 01:09 PM
VaclavSV's Avatar
2012 C63 AMG Black Series
I drive in S+ all the time in winter and use the S+[#] Mode to shift. What the mode lets you do is shift as if youre in manual mode but it will shift for you around the same time S+ would normally shift unless you grab the paddles. From my experience the shift points between S+[#] and M are different.
Old 03-28-2013, 01:27 PM
My question is what's the difference between the shift points for D1 and S1, assuming you let the car shift for you.
Old 03-28-2013, 01:40 PM
vmx128's Avatar
2011 C63 P31
Yeah, in Sx or Cx, it will use gears 1 to X automatically. That part was correct. But if you try going past the redline when you are in say S3, it will shift to the 4th gear and won't limit you to the 3rd gear like you mentioned in your earlier post. So it is not similar to the D321 mode in earlier cars in that way as it does upshift if you try going beyond the redline.
The difference between S and C is the duration of the shifts and how aggressively the upshifts happen. S shifts are faster than C shifts, and S upshifts later than C. Also, if you are not in C1 (i.e. you're in C2+ or regular C mode), you will start in the 2nd gear from a stop.
Quick Reply: Drive mode D1 vs M
