C63 AMG (W204) 2008 - 2015
Help- changing 2012 diffuser
Old 04-13-2013, 03:02 PM
Multani's Avatar
2012 C63
I am trying to change my diffuser. Does anyone know how to do it?
The screw that is on it is different from thr other DIY
Old 04-13-2013, 05:56 PM
natman316's Avatar
2012 C63 2015 C300 sport
you mean the two sides? THey are rivet and you have to drill them out.
Old 04-13-2013, 07:39 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Yep it's rivet. Just drill a little it will get loose. The rest of the diffuser is clipped. Good luck!
Old 04-14-2013, 01:03 AM
Fung63's Avatar
my wife bananas! :D
cant see it too clearly but that is the spot connected to the bracket right? you can actually take the bracket off with the diffuser no need to mess with the rivets
then you can either fabricate brackets (i will show you mine tomorrow at the meet) or you can go get long bolts like some members suggested
Old 04-14-2013, 09:14 AM
noodleman's Avatar
2014 E63S Wagon
that looks like the torx screw on the side of the bumper.
hmm, at least on my car it was a torx screw. That does look like a rivet though.
Old 04-14-2013, 04:41 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
That is definitely a torx screw, it should be easy to remove with the right torx screwdriver. I also unbolted the whole bracket attached to the diffuser, i didn't bother drilling the rivets out. I used longer bolts for the new diffuser instead.
Quick Reply: Help- changing 2012 diffuser
