C63 AMG (W204) 2008 - 2015
Can dealership reset ECU?
Old 04-23-2013, 04:50 PM
w204nyc's Avatar
2017 C63S coupe '09 C63, '15 Durango RT, '14 Jeep SRT8
I had my car at the dealership for a CEL and it was a O2 Sensor again. A guy there was telling me they usually reset ECU's after they put new sensors in. Is it possible that they reset my ECU? My car feels slow as ****!
Old 04-23-2013, 05:52 PM
CarHopper's Avatar
E63S | X5
Were you tuned before? Because they in theory could but I doubt it would remap the whole thing to lose any type of tune...
maybe?
Old 04-23-2013, 06:00 PM
w204nyc's Avatar
Yes OE Tune!
Old 04-23-2013, 06:38 PM
BAD430BENZ's Avatar
360 Modena TT
look it up in the search bar.....they can flash you back to oem . if you don't have a mod friendly dealer , then you need to get a handheld device for your tunes or get a spare ECU
Old 04-23-2013, 06:42 PM
Fung63's Avatar
my wife bananas! :D
or just get oe to reflash your tune.
Old 04-23-2013, 07:01 PM
w204nyc's Avatar
Damn they probably did reset it. I will speak to OE!
Old 04-24-2013, 04:09 PM
Mort's Avatar
If they reset the ECU it should say so on the repair order. Call them and ask if you are not sure.
Old 04-24-2013, 09:06 PM
SoFlaC63's Avatar
96 C220, 85 300D, 2012 C63 AMG
ehhhhh be skeptical of this. When your car has a check engine code, and they do the repair all they do is clear the codes. Basically pulling a battery cable to clear the computers memory. Obviously they use STAR diag. but it does the same. I honestly don't even know if they can see if its been flashed, possibly but i dont know how in-depth STAR diag. is. We use many scanners at our shop, none of which could remap or edit computer files. It will relearn everything and you would NOT lose your tune after clearing the codes.
On the other hand if they reflashed your computer, i.e. software update then yes, its possible. I wouldn't be under the assumption that they would let you know there was a software update. Plus a flash would take much longer than a simple wipe of codes. Hence a bigger charge for such a thing. (assuming your not under warranty)
Quick Reply: Can dealership reset ECU?
