C63 AMG (W204) 2008 - 2015
Old 06-04-2015, 07:37 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Specifications and General Maintenance
Print Wikipost
HELP.... Car won't start
Old 05-04-2013, 11:41 PM
Jeremy6612's Avatar
C63 AMG
08 C63 AMG
Car will not start. Everything was fine earlier but now it won't work. The key fob will unlock the car, I can turn on the radio and the lights inside but when I turn the key I get nothing. Where should I start?
Old 05-05-2013, 12:09 AM
khaloof's Avatar
2010 C63 AMG
Try unhooking the battery and leave it for 10 mins then connect and try starting.
If it doesnt start then your battery needs jumper cables to help it start the car.
Good luck.
Old 05-05-2013, 12:13 AM
Jeremy6612's Avatar
C63 AMG
Good luck.
Tried that and no luck. I opened the car with the metal cut key and the alarm went off, put the key in the ignition and the alarm turned off so it recognized the key fob. I don't have a spare key so now what should I try?
Old 05-05-2013, 12:21 AM
bhamg's Avatar
C63 AMG
When the battery failed on the M5 it was like that...everything was fine the prior evening but in the morning the solenoid wouldn't even click and the headlights showed no light whatsoever. My SA said that when a cell failed in the battery the voltage was insufficient to activate many basic functions at all.
Old 05-05-2013, 12:24 AM
khaloof's Avatar
2010 C63 AMG
I think you need a new battery.
Old 05-05-2013, 01:03 AM
Jeremy6612's Avatar
C63 AMG
I tried to jump start it and that didn't help either. Also checked all the fuses and still nothing.
Old 05-05-2013, 01:51 AM
mthis's Avatar
Anything W/4Wheels
Did u try using the other key?
How many miles on the car?
Old 05-05-2013, 02:04 AM
MaroonC63's Avatar
2009 Barolo red C63 AMG (SOLD).13' P31 c63 coupe 2012 porsche panamera
Oh, this exact thing happened to my 09 c63 2 months back. Wouldn't jump start either, got it towed. Was a broken steering column they had to replace.
Old 05-05-2013, 09:43 AM
Jeremy6612's Avatar
C63 AMG
I just have the 1 key, 56k miles.
Is the dealership the only place locally I can get a key andif I get a key do I need the car there to program it?
Old 05-06-2013, 08:40 AM
Harold1898's Avatar
2015 E400 Coupe
Just curious, how did you break your steering column and how does a broken column stop the car from starting? All the best.
Old 05-06-2013, 08:47 AM
Childish///AMG's Avatar
C32 AMG 2002, C 63 AMG 2009
I was "Wondering" about that too??
Old 05-06-2013, 08:57 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
My 09 did that last year. Took the service truck at BWI 30 minutes to charge the battery enough for my car to turn over (and when it did.. it had been sitting for about 10 days).. the cold start bark and rumble set off the car alarm in hte beamer parked next to me
The car needs another vehicle with a V8 to jump it, if you tried with anything less, that car will have to sit on the gas pedal for a very long time to generate enough charge to get your battery (assuming it is not dead) for your car to turn over.
Old 05-06-2013, 09:35 AM
olszowa12's Avatar
'08 C63 Estate
My '08 had the same problem.
Steering column was replaced.
https://mbworld.org/forums/c63-amg-w...preciated.html
Old 05-06-2013, 11:39 AM
Jeremy6612's Avatar
C63 AMG
Steering column lock. 1100 to fix and the extended warranty won't cover it. Car is 3 weeks old and already dropping 1100!
Old 05-06-2013, 12:41 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
Why won't they cover it?
Old 05-06-2013, 01:15 PM
Jeremy6612's Avatar
C63 AMG
They say it is a serviceable part and it isn't stated exactly in the coverage that it is covered. Steering column is covered but not the steering lock.
Old 05-06-2013, 01:27 PM
Hmm, I would disagree. It's not like a set of tires or brake pads where they eventually wear down and will need replacement. Have you tried to ask another dealer?
Old 05-06-2013, 01:42 PM
MaroonC63's Avatar
No idea, came back to the car and it just wouldnt start, not with the spare either. Had a 5.0 and a charger try to jump start it but wouldnt work. The tow truck with a v10 tried also without any luck. The dealer told me the steering colum was to blame and they fixed it all under warranty.
Old 05-06-2013, 02:16 PM
adv4nced53's Avatar
2010 C63 AMG
Had this issue on my old C300. The RFID reader failed. Had to get a new one and a to reprogram both keys.
Old 05-06-2013, 04:26 PM
Jeremy6612's Avatar
C63 AMG
I agree but I bought a aftermarket warranty that isn't through mercedes so no matter where I go they are going to decline it.
I was told there was a possible recall on that part so trying to fight it.
Old 05-06-2013, 04:29 PM
Oh yeah, then I'd definitely dig into that. What vehicle range was that recall for?
Old 05-06-2013, 04:30 PM
iamtodd's Avatar
2009 C63 - 2019 C43
I had the same problem on my 09 about a month and a half ago. I was out of warranty so it was all out of my pocket. I was going to get the part and have my mechanic replace it, he only works with MB. Found out that the dealer will not sell me the part and that THEY have to replace it due to "theft relevant parts" it's all BS if you ask me. So yeah cost 400 more through the dealer than what my mechanic was going to charge. It is what is is....i guess.
Old 05-06-2013, 05:54 PM
Harold1898's Avatar
2015 E400 Coupe
dealerships will do whatever they can to get the full charge for their labour and parts rather than the discounted rate under insurance schemes.
Old 05-08-2013, 12:04 AM
roadtalontsi's Avatar
10 C six trizzle
there is no recall on the part and there isnt going to be. The steering lock is in direct communication with the eis, so if it takes a **** than the car doesnt recognize communication with eis thats why you turn the key and the cluster doesnt recognize it or anything. Sometimes you get lucky when your stranded leave the key in for 20min and it will randomly wake up and start working. should be 3-4hrs labor max. and i think the part is 500$? 1100$ seems alittle excessive for that repair but whatever you got your car back.
Old 05-08-2013, 03:13 AM
olszowa12's Avatar
'08 C63 Estate
I paid exactly the same amount on the other end of the world.
Quick Reply: HELP.... Car won't start
