C63 AMG (W204) 2008 - 2015
2012 19" recommended wheel tire pressure???
Old 05-05-2013, 01:05 AM
tdotjag's Avatar
2012 C63 w/APX
I'm running OEM multi spoke 19's on my 2012 C63. Recommended tire pressure is 51 on the backs and 46 on the fronts. Seems a bit too high to me. What's everyone using as their current pressures (to those with the same wheels)? Tires are yokahama advans.
Thanks, jag
Old 05-05-2013, 10:09 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Where did you get those numbers? My car sticker on the door panel says 41f & 45r.
I'm running 40 all around w/ my multispokes for a comfy ride. 38 with my HRE.
Old 05-05-2013, 11:29 AM
nd143's Avatar
SLK
i have 46 Front and 49 Rear, thats wat the door says for me
Old 05-05-2013, 11:49 AM
Roswell's Avatar
This is odd that MB recommends different tire pressure on each vehicle.
Old 05-05-2013, 03:30 PM
tdotjag's Avatar
2012 C63 w/APX
Same as you... From the door panel
Old 05-05-2013, 03:35 PM
tdotjag's Avatar
2012 C63 w/APX
Are u running the 19" multi spokes?
What tires?
Old 05-05-2013, 03:36 PM
tdotjag's Avatar
2012 C63 w/APX
It is odd.
What tires do u have on? Are they still the OEM?
Old 05-05-2013, 03:38 PM
tdotjag's Avatar
2012 C63 w/APX
Maybe Gthal could chime in?
Old 05-05-2013, 04:32 PM
MIKE ZELL's Avatar
It varies.
My info is on the inside of the fuel door. It states 38front 41rear, 3 passengers. 42f, 46r, 5 passengers, for speeds up to 155mph.
42front 44rear, 3 passengers. 45f 49r, 5 passengers, for speeds up to 174mph!
Old 05-05-2013, 05:15 PM
Roswell's Avatar
Originally Posted by tdotjag
It is odd.
I'm on stock tires & stock size Yokohamas AVS Sport.
Old 05-05-2013, 10:09 PM
Thrilla's Avatar
2014 C63 AMG 507 sedan
+1
It doesn't matter what wheels you have, tire pressures should run the same. I follow the recommendations on the fuel door. 40 psi all around, ranging from 1-2 occupants in the car.
Old 05-05-2013, 10:25 PM
tdotjag's Avatar
2012 C63 w/APX
Originally Posted by Thrilla
+1
I agree with you, but why do we all have different recommendations on the inside of our doors? As I mentioned earlier, the inside of my door says 51 on the rears and 46 on the fronts. Seemed high to me, but I've kept them that way since purchase. I'm thinking I could be getting better traction and a smoother ride with lower pressure on all 4 corners. I'm thinking of dropping the pressure by 5 on all tires. Any thoughts?
Old 05-05-2013, 10:37 PM
Thrilla's Avatar
That's the great MB mystery. Like you, I thought the recommended pressures inside the doors were quite high, and I suspect the ride will be very jarring. The numbers inside the fuel door makes more sense to me.
Quick Reply: 2012 19" recommended wheel tire pressure???
