C63 AMG (W204) 2008 - 2015
service B questions
Old 05-06-2013, 01:58 AM
natman316's Avatar
2012 C63 2015 C300 sport
service B questions
so what all is included in this service? from what I gathered in the manual, its an oil change + a bunch of random checks n tire rotations + air filter and cabin filter change. is there anything else required? (just want to make sure)
The dealer wants 590 to do this, which i dont feel like paying 590 for an oil change. Could I just ask them to do the oil change and filters? Or I might just DIY it and keep receipts.
also, for air filters is it worth it to upgrade to performance filters or stock is more than enough.
thanks
Old 05-06-2013, 10:05 AM
jellis102.com's Avatar
KTM 200 xcw
From my research, the above things are all that is included in the B service, which is what I did myself yesterday, except for the cabin filter b/c it hasn't arrived yet.
Other than the dealers, I found the correct oil at Pepboys only (lucky me, they gave me a $20 coupon to use then), no other auto parts store carries the M mobil 1 that I have been able to find. I had to get my filter through O-reilly auto parts and ordered the cabin filter through autohauz. I've reset my service indicator and all seems to be good for now.
The car is using some oil, no leaks that i've found so I bought an extra qt of oil to keep up with the usage.
Old 05-06-2013, 10:47 AM
NCBob's Avatar
2012 C63; 2011 E350 Coupe
Any special trick to resetting the service indicator?
Old 05-06-2013, 10:58 AM
KTM 200 xcw
Being new to the car, it took me a few times to get it right, I just followed instructions I found and it went away.
Old 05-06-2013, 03:18 PM
natman316's Avatar
Thanks. I got the dealer to do oil change, i think i'll just change the filters myself
Old 05-06-2013, 04:52 PM
KTM 200 xcw
What did they charge to do the job?
Me doing it myself, including 1 extra qt of oil, wix oil filter and the cabin filter, cost me right at $170 give or take a few bucks.
Old 05-06-2013, 06:37 PM
natman316's Avatar
not sure but around 230 bucks with the cabin filter. I'll do the next in between interval oil changes myself using a mityvac, but I thought just to have a relationship with my service dept as well as draining out all the oil from the oil cooler i'll have the dealer do this one
Old 05-07-2013, 03:03 PM
mvp2765's Avatar
C
Is that how much an oem, diy, oil change is on this car? $170? Also about how many miles do you guys go before you change the oil?
Old 05-07-2013, 03:43 PM
natman316's Avatar
I had it done at the dealer was around 150 w tax. I believe if you DIY it would be around 90-100 for oil change.
Cabin filter is around 60.
I just follow the manual regarding oil change which is ~10k although i actually changed both times closer to about 8-9k. Thinking about starting to do in between oil changes now since im at 18k miles
Old 05-07-2013, 03:44 PM
KTM 200 xcw
yes sir, I'm sure you can save a few bucks if you find some cheap deals on the parts through amazon or autohauz, the oil is just a bit cheaper on amazon right now but I didn't want to wait for that to arrive, I needed to change it this past weekend.
Mobil 1 105856-CASE M 5W-40 ESP Formula Motor Oil - 1 Quart, (Pack of 6) : Amazon.com : Automotive Mobil 1 105856-CASE M 5W-40 ESP Formula Motor Oil - 1 Quart, (Pack of 6) : Amazon.com : Automotive
I bought my cabin filter on Thursday at autohauz and should have it delivered today.
Old 05-08-2013, 08:54 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Cultivate a good relationship with your parts guy at the MB dealership. You will find that they will give you a good deal, and at the same time, you now have a record of your purchases at the dealership, which can be used in conjunction with your own documentation to substantiate the services being performed if the service history comes into question during a warranty dispute (I have not had a dispute yet, but its good to keep your behind covered).
Typically, for 10 quarts of oil, and a filter, I pay around $80
Old 05-08-2013, 09:27 AM
KTM 200 xcw
Where are you getting your supplies from and what type of oil/filter are you using? That is pretty cheap there.
Old 05-08-2013, 10:17 AM
jvanbrecht's Avatar
Like I said, cultivate a relationship with your dealer's parts department. Without going into details, early on the dealer made a mistake with apart I ordered, that mistake resulted in no major issues, but it ended with me talking with the parts dep quite abit early on, and a good relationship followed on. They now take care of me when I come in every 5k miles (the intervals at which I change my oil).
Obviously my situation is unique, and your experience may differ, but it never hurts having a good relationship.
Old 05-08-2013, 11:07 AM
natman316's Avatar
i think i can get them around the same price. 6.25/ qt mobil 1 and oem filter is 30 i believe.
Old 05-08-2013, 11:24 AM
KTM 200 xcw
Just make sure that you get the Mobil1 "M" instead of Mobil1 oil, it is quite different, at 6.25 per qt, I doubt you're looking at the correct oil. IIRC my wix filter was $21 at O'reilys.
Old 05-08-2013, 11:26 AM
jvanbrecht's Avatar
I believe the 0w40 and 5w40 only come in M formula, but I could be wrong..
Old 05-08-2013, 11:47 AM
natman316's Avatar
Not sure but those parts are straight from the dealer which are the same one they use for oil changes
Old 05-08-2013, 12:56 PM
khmergod's Avatar
2011 P31 C63 2015 CLA45
Unfortunately I was already 1 month late on my B service, so I decided to lube up my anus. I paid ~$650 for a 1 hour service B. On the bright side, I went to discount tire and they prorated my Michelin PSS 275's and discounted me 80% on my next set aka ~$400, but reduced my new tires to 265 since they updated new specs and that was the max that they would install.
Old 05-12-2013, 01:34 PM
Zipper4's Avatar
SLK 350
2012 SLK350 dealer wanted $895 to do service B, bought all filters, oil, DIY but cannot figure how to reset service alert. Can anyone help out with instructions?
Old 05-12-2013, 01:39 PM
NCBob's Avatar
Cannot remember but the operator book has the procedure
Old 05-12-2013, 01:57 PM
Zipper4's Avatar
SLK 350
Having a heck of a time, manual does not explain it so I can reset...usually good at this but this one can't figure.
Old 05-13-2013, 05:40 PM
Mort's Avatar
Here ya go
https://mbworld.org/forums/attachmen...ator-guide.pdf
Quick Reply: service B questions
