C63 AMG (W204) 2008 - 2015
Different airbox type on both sides!
Old 05-12-2013, 09:25 PM
Nface21's Avatar
AMG C63 2010
I was just taking a peak at my air filtration system. I bought this car about 3 month ago and I was considering doing the "charcoal delete" and changing the air filter in the same process.
Once I opened up both airbox, one had the charcoal filter and the other not? Is this specific in canada? I am a bit confused.. Can this mean I had half of a ROW airbox mod? Should they be both the same?
Thanks!
Attached Thumbnails Different airbox type on both sides!-intake1.jpg   Different airbox type on both sides!-intake2.jpg
Old 05-12-2013, 09:44 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Lol! Yeah looks like half ROW airbox mod to me. Never seen this before. Interesting...
Maybe something happened to the original box and it was replaced by a ROW box. I dont know just guessing!
Old 05-12-2013, 10:25 PM
SROC276's Avatar
2010 C63 P31 AMG
Thanks!
Weired same thing happened to me and I bought a certified c63 with no mods...one side was row and the other usual airbox. Prior owner did not modify it as far as I know.
Old 05-12-2013, 10:35 PM
Nface21's Avatar
AMG C63 2010
Should I order only the missing side and get them both the same? I mean this MB has been serviced at the dealer always, if this was not normal wouldn't they have noticed when doing routine air filter replacement? What did you do?
Old 05-12-2013, 10:42 PM
SROC276's Avatar
2010 C63 P31 AMG
Weired thing is we both have the same side that was the row and other side normal! I went all the way and replaced everything with my carbonio intake....that's the only reason I found out about the airbox difference was when I was replacing it at home.
Old 05-13-2013, 12:38 AM
NellyRod's Avatar
2012 C63 AMG BS, 2010 DUCATI 1198S
What's your thoughts on the Carbonio intake so far?
Old 05-13-2013, 09:04 AM
jellis102.com's Avatar
KTM 200 xcw
I'm not convinced that this is not done from the factory, as mine is the exact same. I don't know why there would only be 1 C/F out of the 2 air boxes but there must be a reason.
If you're going to change 1, why not just change both at the same time.
The car I bought is/was stock when I purchased it, with stock filters, when I changed to the AFE filters, there was enough dirt, dust, bugs in the stock filters I had to sweep the mound up, the air box tops were different from each other just as pictured above.
Old 05-13-2013, 09:12 AM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
I had the EXACT same thing here in the US! I have a 2010 too... only one charcoal filter too...Very strange.....
Old 05-13-2013, 12:13 PM
SROC276's Avatar
2010 C63 P31 AMG
I love it...dresses up the engine compartment very well and provides some mid to high end power increase from the butt dyno but not sure. the engine note is also different which I like very much. Install was fairly easy other than fitting one side of the maf sensors which required me to widen the port a little on the intake tube using a dremmel. I guess it was a molding issue with the one side. overall excellent intake and no check engine lights.
Old 05-13-2013, 12:59 PM
crazy1eye's Avatar
2016 C63S, 2012 ML350
Ok, now I'll have to check mine when I get home
*** Checked them & I have both
Old 05-13-2013, 01:16 PM
KTM 200 xcw
LOL, everyone will be doing it now
MB
Old 05-13-2013, 03:29 PM
uclachan's Avatar
10E63
Hi folks,
I have 2010 E63.
have the same thing.
I contact the dealer / MBUSA to find out what is going on.
On the other hand, my friend's E62 (2010) has both charcoal filter.
weird.
Old 05-13-2013, 04:08 PM
sfury63's Avatar
2012 GTR/2010 C63
Same thing happened to me. I discovered mine by way of a CEL.
I just ended up getting a row intake for the other side.
https://mbworld.org/forums/c63-amg-w...us-airbox.html
Old 05-13-2013, 09:35 PM
Nface21's Avatar
AMG C63 2010
So it is safe to assume this came out of the factory like that, I still find it odd, since it would clearly have a different airflow on the left side and the right side. I guess its time to see if I can get only the right side airbox...! Well at least I am not the only one! lol!
Old 05-13-2013, 10:00 PM
SROC276's Avatar
2010 C63 P31 AMG
Probably think they ran out of more restrictive boxes and used euro versions during build. Maybe a certain production date of amg m156 engines...I am guessing we have two 2010 so far.
No wonder my car used to pull left under hard acceleration...more power on left side...
Quick Reply: Different airbox type on both sides!
