C63 AMG (W204) 2008 - 2015
Advise about the HR spring( picture attached)
Old 05-13-2013, 10:50 PM
kg21nba's Avatar
C63 coupe EVO X(sold) WRX (sold)
Right now my setting is like this:
20x8.5 front
20x10 rear
with HR 10mm spacer for rear
Tire is Pirelli P Zero
If I install the HR spring(lower 0.75"), will it rub the fender at the back?
Any member had an experience with this?
Attached Thumbnails Advise about the HR spring( picture attached)-20130513_224032.jpg   Advise about the HR spring( picture attached)-20130513_224119.jpg
Old 05-13-2013, 11:18 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
We need to know the offset & tire size.. but from looking at your pics... yes, you will rub!!
Old 05-13-2013, 11:19 PM
Roswell's Avatar
BTW, why do you need the 10mm spacers in the rear on your 20x10? Calipers clearance problem?
Old 05-13-2013, 11:39 PM
kg21nba's Avatar
Ya, because when I order my rim from the company, they made a mistake about the offset, so I need a spacer to pull out the rear rim more.
Right now my offset is +55 rear.. And rear tire is 285/25,front is 245/30
So will it rub?!
Old 05-13-2013, 11:45 PM
Roswell's Avatar
+55mm including the spacers or +45mm with the spacers?
If the first case, you should be ok with 20x10 +55mm (not sure about the 285/25 though)... if you rub, you can go down to 275/25.
If the second case, you will rub for sure at 19x10 +45mm.
Old 05-13-2013, 11:55 PM
kg21nba's Avatar
My rim itself is offset 55, and + the 10mm spacer.... So I guess I can't go with spring, maybe coilovers?!
Old 05-14-2013, 01:20 AM
Roswell's Avatar
I knew they were 20x10 +45mm from looking at the pics.. They look very aggressive.
Coilovers won't help ur case, unless u want to lower the front only & not touch the rear (rake look). U will rub no matter if u do coilovers or springs. U should just stay at stock height, or return the wheels. May I ask the brand of ur wheels? Better pics of the car? Thx
Old 05-14-2013, 05:09 AM
wibi88's Avatar
c63
20x8.5 front
20x10 rear
Yeap, i did it with a 20" rims, and the back tire was rubbing the vender. I'm using a 2009 C63.
Old 05-14-2013, 09:58 AM
JeffDL's Avatar
C63
adv strikes again?
Old 05-14-2013, 10:02 AM
Roswell's Avatar
LOL @ Jeff, they look like ADV wheels.
Old 05-14-2013, 10:22 AM
VaclavSV's Avatar
2012 C63 AMG Black Series
20x8.5 front
20x10 rear
Is your cr the yellow with black pinstipe from restyle it? ... Pic of the wheels?... Ive only ever seen it on stock wheels
About the rubbing you will probably rub. Im lowered on 19" monobocks 8.5 front and 10 rear and Ive rubbed a little and bottomed out the front and bent the drivers side fender.
Old 05-14-2013, 02:33 PM
kg21nba's Avatar
:< i guess i will forget the low down then. Sure, Im about to photo shooting my car. I will upload mu car ASAP, right now is still really dirty
Old 05-14-2013, 02:34 PM
kg21nba's Avatar
HA! Where did you saw me? Ya i just changed a shoes for my car coupe weeks ago! So i guess i will keep my stock height then....
Old 05-14-2013, 06:26 PM
Former Vendor of MBWorld
SupremePower1's Avatar
Coupe
Wheels look like BC Forged.
20" wheels can fit and not rub. Suggest trying a 5mm spacer in conjunction with the drop if you do rub. Rear brake clearance usually isn't an issue...unless somehow the wheels were built completely wrong but don't see how that would be possible.
Quick Reply: Advise about the HR spring( picture attached)
