C63 AMG (W204) 2008 - 2015
Heat Under the Door
Old 05-30-2013, 06:55 PM
deadfission's Avatar
2010 C63 AMG, 2011 Mini Cooper (work)
Heat Under the Door
Does anyone else get an enormous amount of heat that comes out from the driver side door? Like at stop lights if I have my arm out the window its like 100+ degrees coming from under there and when I open the door to get out of the car. I've never had a car that pumps out heat like that so close to the door...
Old 05-30-2013, 07:08 PM
kaunain13's Avatar
C63 AMG Coupe
Yah I get that too after some spirited driving. I thought it was a little odd too.
Old 05-30-2013, 08:51 PM
dcm95ss's Avatar
c63, '65 buick riviera, '65 impala, s63
My car does the same .... Puts off alot of heat
Old 05-30-2013, 10:33 PM
khmergod's Avatar
2011 P31 C63 2015 CLA45
Lots of heat when I park it in the garage after a drive.
Old 05-30-2013, 10:59 PM
JCH
JCH's Avatar
2009 C63
Yep
Old 05-30-2013, 11:15 PM
CarHopper's Avatar
E63S | X5
It's normal. It's hot out and you have an engine that is a couple hundred degrees. Heat has to go somewhere
Old 05-30-2013, 11:52 PM
Case1906's Avatar
AMG GTBS, AMG GTR Pro, AMG GT, C63 AMG, Porsche Panamera 4S, RX-7 FC Turbo II
hawt, hawt, hawt, hawt.....
Old 05-31-2013, 12:37 AM
604 C63's Avatar
2012 E550 Cabrio
To tell the truth, I cant remember the last car I owned that DIDN'T do that.
If its not too hot, you're driving too damned slow!
Old 05-31-2013, 09:11 AM
dcho's Avatar
dreams
yeah, i've noticed this too. mounted a gopro to the back bumper once and it was almost too hot to touch when time came to remove it.
Old 05-31-2013, 09:19 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
The Catalytic converters are right under the car near the doors. They get hot.. as in 1000F+ hot. While it is shielded (the insides actually get that hot, outside shell probably gets to around 500 to 800F). What you are feeling is heat from them radiating off the ground.
Old 05-31-2013, 09:34 AM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
yep, lots of heat....
Quick Reply: Heat Under the Door
