2013 C63 Black Series Tire Pressure Question
2013 C63 AMG Black Series
Guys,
I have a 2013 C63 Black Series with both the track and aero packages. I had low tire pressure in my left rear tire, so I went to the inside of the door panel, and it says to fill up the rear tires to 48 PSI and the front tires to 46 PSI. Is this correct? It seems a little too high. Thanks!
Nick
Nick
Administrator
2020 Audi R8 V10, 2016 AMG GTS, 2018 E63S Edition 1, 2018 Porsche GTS Cab, 2012 C63 BS
Door Jam, drivers side---- I run non track and low load (limited passengers and luggage) is 34 psi.
You are reading the max psi for a full load Im sure. You psi will be different than mine since you have different tires and the track set up.
