722.9 Transmission shifting problem
e55 2004
Hi, everyone. I noticed that my transmission is forgetting to shift up after harder breaking. I need to use pedals to change to the next speed.
The transmission is smooth on every gear changes, even from 1 to 2 and from 2 to 1.
When I am driving at 7th gear (speed 60) then braking, transmission downshifts to 3rd, 4th or 5th (speed can be from 25 to 40) normally like suppose to be. When accelerating to the same speed (60) and transmission sometimes forgetting to upshift to the right gear (can stay on 3rd, 4th, 5th) with high RPM. Doesn't matter if it is sport or comfort mode. I am using pedals to change the gear and it helps. It is not always happens, maybe two times a day, more often after harder braking.
I have DAS, No fault codes present...
Maybe I need to reset the adaptation? But dealer recommends to do reset only after repair.
Please help. Thank you!
What mode are you in? Are you running in M? If so it will rev to a higher RPM before shifting because it thinks you want to shift yourself rather than an automatic upshift.
e55 2004
e55 2004
Thank you!
SL55, C63
sounds normal. when you drive aggressively it does too. It will hang gears if you floor it and let off, because it thinks your going to punch it again. just tap/hold the upshift paddle or floor shifter to the right.
