C63 AMG (W204) 2008 - 2015
What is Leaking from my Car?
Old 06-16-2013, 12:00 PM
JPetros2008's Avatar
2016 AMG GTS
Got an oil change and brake fluid change from my dealer a week or so ago. Haven't driven the car since getting it back and parking it in my garage. Backed the car out into the driveway today and saw this fresh orange fluid on the ground. It was still wet so it must have started leaking after I started the car. Does anyone know what it is? Am I in trouble?
Old 06-16-2013, 12:02 PM
Merc63's Avatar
C63 AMG
Brake fluid
Old 06-16-2013, 12:03 PM
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Touch, feel, and smell it. Is it greasy or water like? If the latter, it could be AC condensate that dripped onto something dirty, and then to floor. Could also be spilled BF that finally dripped down.
Old 06-16-2013, 03:28 PM
2016 AMG GTS
not at home anymore, but is this something that I should be worried about? should I immediately take it back to the dealer or is it probably just a one time instance not from a leak somewhere?
Old 06-16-2013, 04:39 PM
bhamg's Avatar
C63 AMG
Thumbs up
Brake fluid is extremely corrosive on paint. You do not want wind-blown brake fluid deposited on paint as best case you will see permanent spots if not rinsed off. If it is brake fluid and it were my car I'd rip the tech a new one...no excuse for that IMO.
Old 06-16-2013, 04:53 PM
CoolBDPhenom03's Avatar
Vivid Racing '09 C63 AMG
Do this, overnight, place some cardboard or something under your car to determine if there's a leak at all. Then, you can analyze the viscosity and smell of the fluid to determine what it is.
Old 06-19-2013, 06:47 PM
2016 AMG GTS
tried smelling it today, but couldn't really get a scent. there was more leakage on the driveway after i took it out, but then i saw that it might be coming from the exhaust. is it just dirty water? can't tell if it's leaking anywhere from under the car, but i can check again tomorrow...
Old 06-19-2013, 06:53 PM
Hmm, doesn't look like dirty water, but then again, I'm not sure what kind of crud builds up in our exhausts. How does it feel? You should be able to tell if it feels like water or something else.
Old 06-19-2013, 09:08 PM
roadtalontsi's Avatar
10 C six trizzle
water is pretty normal from condensation or bi-product of good combustion, as long as its not coming from the calipers i think youll be alright.
Old 06-20-2013, 09:50 AM
jellis102.com's Avatar
KTM 200 xcw
I'd say condensation as well, with that sitting in the exhaust over night, it will definitely turn colors, I would not worry with it at all. Just drive on.
Old 06-20-2013, 11:43 AM
hevykevy420's Avatar
2009 C63 P30
Oil is seeping up from a gigantic oil deposit directly below your garage. Soon you will be rich beyond your wildest dreams, richer than even the Beverly Hillbillies JK, couldn't resist.
It looks strange, oil is usually clearish (when new) not sure what MB uses for brake fluid but a lot of the german synthetics when new are green or blue (dye). Logically one would think if it is BF from a sloppy install it would only come from the M/C area resevoir, or near a caliper (unless you have a leak somewhere else).
Isolate the general area where its accumulating, get a bright flash light, get it up on ramps if you need to, figure out where its coming from.
Old 06-20-2013, 12:12 PM
Former Vendor of MBWorld
VividRacing's Avatar
G63, C190 AMG GTC, W209 CLK63 BS, W208 CLK430
How often do you drive the car? Does it sit for long periods of time?
Water out of the exhaust is pretty common if the car isn't driven much
Old 06-20-2013, 11:44 PM
10 C six trizzle
it doesnt have to not be driven for long. just long enough to cool off. Benz brake fluid is very clear with the slightest hint of yellow to it. if your fluid looks green or yellow or blue and its not aftermarket you should flush that **** asap.
Old 06-21-2013, 01:21 AM
2016 AMG GTS
I literally just got the brake fluid flushed and changed at the dealer. I used to drive the car daily, but recently got a different car to use as a DD and I haven't really driven the c63 in 2/3 weeks. i'm guessing it's just some water build up then and the brown is just coming from some dirt or build up in the exhaust.
Old 06-21-2013, 02:15 PM
That's what i'm thinking, shouldn't be much to worry about.
Old 06-21-2013, 02:41 PM
Quadcammer's Avatar
96 and 08 911 turbos
that is not brake fluid.
looks like water from the exhaust with some rust mixed in.
Old 06-21-2013, 02:45 PM
Rust can't be good...
Quick Reply: What is Leaking from my Car?
