C63 AMG (W204) 2008 - 2015
Spacer Fitment
Old 06-24-2013, 12:35 AM
YP63's Avatar
2013 C63 Coupe
Spacer Fitment
I am new here but one thing I must change on my car is the wheel/tire stance. I have a 2013 C63 coupe with stock 18 inch AMG wheels and 235/255 set up, I am planning on getting rims in about a year or so but until then I'd like to put on some spacers, and I was wondering if anyone knows the widest front/rear combo I can run without rubbing is. Thank you in advance!!
Old 06-24-2013, 01:16 AM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
welcome! i think your best bet is to search this forum. there are tons of threads on this, including a recent one a little further down the list.
Old 06-24-2013, 09:02 AM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
I wouldn't get spacers until you actually are going to mount the new wheels...
Old 06-24-2013, 09:19 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
Zeph, why not? I've been running spacers & no problem at all. It improves the look of the OEM wheels x100 times better.
Old 06-24-2013, 09:33 AM
ZephyrAMG's Avatar
My limited experience with spacers is that when you place a spacer and new wheel on, the spacer sort of "shapes" to that new wheel and both develop "groves" for one another. Like a cork sandal fitting to a specific foot...switching spacers and wheels will lead to vibration issues and fitment issues in the future...
I have nothing against spacers, just recommending the OP pair the new spacer to the new wheel...
I think we all provide our advice to one another because as members we care about one another's well being, but some advice may be too cautious...please let me know if my insight is a bit extreme and that there are no concerns...
Old 06-24-2013, 07:22 PM
Roswell's Avatar
Very good point bro! But i think OP wants to use spacers on his stock wheels only til he buys aftermarket wheels with a better offset. Well, I think that's what he meant. Lol
Old 06-24-2013, 07:24 PM
Roswell's Avatar
As for OP, u can use 10mm rear & 12mm front w/o rubbing even lowered. (on stock size tires)
Old 06-24-2013, 09:01 PM
khmergod's Avatar
2011 P31 C63 2015 CLA45
Zeph is making a good point. Good thing spacers aren't too expensive. Wheels are one of the most expensive mods to a car anyway. I would recommend getting new spacers for each new set of wheels. What zeph said is logical.
Old 06-24-2013, 09:25 PM
mipis's Avatar
2013 Mercedes Benz C250
How much is too expensive? I have couple of quotes, all in the $200
Old 06-24-2013, 09:29 PM
khmergod's Avatar
compared to other mods, spacers are one of the cheapest
Old 06-24-2013, 09:30 PM
khmergod's Avatar
that's about all the quotes lol, msrp is 100per pair for our car
Old 06-24-2013, 09:33 PM
did you get yours yet??
Old 06-24-2013, 11:20 PM
khmergod's Avatar
Prob by end of week
Old 06-24-2013, 11:46 PM
Roswell's Avatar
200$ for 4 spacers or 2? If 4, it's about correct or else keep shopping.
OP, don't forget to buy longer bolts (37mm or 40mm) & make sure u buy hub centric spacers to avoid vibrations.
Old 06-25-2013, 01:06 AM
Prob by end of week
Where's it coming from, the South Pole? Lol. The wait is killing me more than you!
Old 06-25-2013, 10:28 AM
adv4nced53's Avatar
2010 C63 AMG
I don't understand this statement. If the right materials are used and there are no manufacturing issues, this would never be a problem. Make sure you get hubcentric spacers - H&R has them and from my experience they are quality products. 12mm F, 10mm R is safe. Some people run 15mm F, 12mm R but I don't know how well those clear a lowered car. Don't forget to buy the correct bolts!
Old 06-25-2013, 07:18 PM
Jasonoff's Avatar
Received 1,576 Likes on 929 Posts
2010 C63 AMG
Front: Bridgestone RE760 235/40-18
Rear: Bridgestone RE760 265/35-18
14mm F/R with H&R springs. Fronts slightly rub only on dips at speed. Can't get them to rub cornering.
Old 06-25-2013, 07:30 PM
khmergod's Avatar
How bad is rubbing for the car's integrity?
Old 06-25-2013, 07:37 PM
Former Vendor of MBWorld
Need4Speed's Avatar
2018 C63S
Spacers would be a nice modification if you are looking to go a little bit wider without modifying the wheels/tires just yet. However, I would be careful on what brand spacer to use. Do not buy any universal spacers that is for sure! Any brand of quality, and you should be set. Be sure to check the torque levels of the lug bolts often.
Post up some pictures if you do end up getting the spacers, would love to see them on your car
Old 06-25-2013, 07:41 PM
Jasonoff's Avatar
2010 C63 AMG
That really depends how bad it is. You could buckle a fender if it rubs during turn in on a hard corner if it catches a tread block.
Whit I posted is very minor. Just enough to make a whitness mark. Over time it may rub the paint off but the front fenders are aluminum so it doesn't bother me.
Old 06-25-2013, 07:50 PM
Holy cow, I didn't think 14mm would work in the back with 265s. Good to know. I'll prob go with 10mm rear, though. I was gonna do 5mm rear with 265, but figured that's like putting nothing in there. Lol.
Old 06-25-2013, 08:05 PM
Jasonoff's Avatar
2010 C63 AMG
I listed the brand/model of tire so you can look up the tread width. Keep in mind it may not work with a different brand/model 265.
EDIT: I was curious. Below are the important numbers for the 265.
Section Width: 10.7"
Tread Width: 9.5"
OD: 25.3"
Old 06-25-2013, 08:13 PM
khmergod's Avatar
Thanks for being the guinea pig. I'll just stick to 10mm to be safe. Comes in tomorrow! Install on Thursday! awww yeaaaaa.
edit. fml I reread the post and said you rubbed on in the fronts on springs at 14mm. I have 15mm on the way lol!!!! good game khmergod, good game.
Old 06-25-2013, 08:26 PM
Tread Width: 9.5"
OD: 25.3"
i see. i was gonna get PSS', but those are 10.1 tread width, which is another .3 inch per side. how do you like the 760's?
Old 06-25-2013, 08:32 PM
khmergod's Avatar
Hey Jasonoff. Can you fully turn your wheel left and right without it rubbing anything on the inside?
Quick Reply: Spacer Fitment
