Intake Gasket DYI - help
I am looking for a DYI on the Intake Gasket for the the M156 engine. I have allData DYI, but I'm stuck as I do not have the special tool to release the pressure in the fuel lines. Any help here?
Shouldn't be much pressure if you let it sit for a day or two. I took my fuel line off, fuel pissed out, but no pressure.
Bolts are TTY on the intake,you will need new ones.
C63AMG, NIssan NX2000, Pontiac Fiero GT
On other cars with fuel injection I have carefully broken loose a line fitting and held rags around the joint. This is potentially dangerous with any spark source (drop light etc) as the line pressure is 45-80 psi. Other procedure I remember : pull fuel pump fuse and run car (if it will) until it stalls. A reminder: 80 psi is about like your city water hose connection. No barbecue allowed!
