Need Help - Odd Engine Ticking Sound
Hello Everyone,
So, I haven't driven my car around in about a month now (waiting on my interior to be finished, should have it back in a week). Anywho, I have been starting up the engine and letting it idle just to keep things going every 4-5 days.
Now here's the problem, yesterday I start it up and I hear an odd ticking sound. I used the search and found other threads about it maybe being lifters or cams or something (not very mechanically inclined here) and from those threads it said its normal after the car has sat for a while.
Anyway, I have attached two videos of the sound. I didn't let the car warm up all the way (only to about 100 degrees) because I was afraid it might be bad.
Any advice and help would be greatly appreciated.
Haven't driven it yet. After I heard it I turned it off and came straight here to ask. Didn't want to cause any damage, but based on the other threads I saw about this I am going to let the car warm up all the way to 176 then go for a light drive to see if it goes away.
In the meantime, any other thoughts/ideas/suggestions?
2012 C63; 2011 E350 Coupe
I strongly suspect lifters. When the car sits for an extended period of time, the lifters will collapse a little. You really need to get it up to operating temp and it should go away. I've had that happen to other cars, but not the C63 as it is a daily driver.
So if it was the lifters, is this a problem I should have looked at? Or is it normal for cars that have been sitting for a while? Basically, should I expect problems from this again (once my interior gets back later this week the car will be a DD again)
if the car is sitting around for a long time the lifter will make that sound, take it for a 1 mile drive and it should be gone by then. its sound like its just a lifter and nothing more.
07 E63 + 07 CLK63CAB
Lifter tick, how long has the oil been in the car mileage wise?
These car do not like to sit, but with that said mine sat all winter with only one start and run to full temp. Check with dealer which oil he used 0w40 or 5w40, only time I would be worried if the oil level was way low and heard this noise continuously when warm.
IMO you do not have an issue, you must drive the car to operating temp, What has happened is that when the engine was shut down the last time the cam lobe was at or near the highest amount of push on the lifter valve assembly and over time the oil has been bled out of the lifter causing air to be introduced and it will take time for the oil to displace the air. Sometimes one can start the car hear the noise run for a minute, shut the motor down and then restart, no noise. But if it continues, take it to the dealer and let if sit overnight and be there in the morning with the tech and then start the car with him standing there. If at all possible do not let them tear apart the motor for the sake of a sometimes tick. JMO
Thanks everyone!
Appreciate the info and that seems to be what it is. I will take it for a quick drive around later today but even just idling the sound has gone so I think its ok.
Thanks again for putting my mind at ease.
98 Prelude
I have a 2013, 1500 miles on it, and just had the exact same thing. I could post the video but it's identical to yours. I drive mine 3 days a week and had taken it out the day prior to the tick.
Shared the vid with my dealer and had them check it out. They checked the car and the AMG guy shared the vid with MB. MB said it's not an issue. Worst case it's documented.
They mentioned other cars had been there for the same thing.
When you guys say "it's the lifters" does that mean it's an unlubricated cam lobe hitting the top of the bucket tappet, causing the ticking noise? Or, is it the bucket tappet itself sliding unlubricated until it actuates the valve, and that action is the cause of the tick?
