Work Meister S1r question!
2010 C63 AMG
Hey guys,
New owner here, picked up a 2010 C63 AMG in white, fully loaded except for performance package!
I have an opportunity to buy a set of rims from a friend of mine, specs are
Work Meister S1r in flat black
Front: 19x8 +35mm offset running 245/35/r19 tires
Rear: 19x10 +45mm offset running 275/30/r19 tires
Will this setup work on a stock suspension without rubbing on turns / fenders etc?
Rears will come out 22mm from stock and fronts will come out 10mm from stock. Inner clearances will be fine
hello my friend Running those wheels right now
I'm running 19x9+40 with 235/35/19 fronts and 19x10+53 with 265/30/19 with no rubbing.
I'm planning to play with some spacers to make it abit more flush. Your offset and tire sizes will likely rub on stock suspension.
If it's your friend's wheels, will he let you just mount them to see if there's a problem?
edit: here's a pic for reference for size/offsets, i'm lowered on H&R springs.
Hey guys,
IMO you will probably rub front and rear with these offset and tire size.
I'm +40 and 245 on 8.5x19 wheels front, +48 and 275 on 10x19 wheels rear and do not rub under normal conditions. But that's the limit. I wouldn't try more and it's pretty flush.
As noodle mentioned ask your friend if you can try the wheels and check. GL
From the offset calculator his 19x8+35 retracts by 1mm to your 19x8.5+40, so the fronts should fit without issue. It's really the rear he has to worry about, and if he likes the slightly poked look.
2010 C63 AMG
Update: Tried a test fit except I ran into one problem. The OEM lug nuts are too thick to pass through the 114mm holes on the rim. I was abit surprised about that... What are the other options to mount?
I'm pretty sure Work wheels are cone seated, our OEM are ball seated.
U have no other choice but to get the right lugs that fit our vehicules & these wheels for safety.
are you sure these wheels were made for Mercs with M14 bolts? I know some Mercs use M12 bolts.
the bolt pattern/size should be on the back of the wheel.
