C63 AMG (W204) 2008 - 2015
Steering Wheel Shakes
Old 08-29-2013, 09:52 PM
C's C63AMG's Avatar
2010 C63 AMG
I need some advice, when I put my C63 2010 on drive/reverse and turn the steering wheel all the way to right n left, I can feel the vibration. I took it into the dealer and they replace the power steering pump and that did not solve the problem. Please advise if you encounter this problem.
Old 08-30-2013, 09:40 AM
Mort's Avatar
Sounds to me like the pressure relief valve in the hydraulics of the power steering system. Don't hold the steering wheel hard against full lock it is very hard on the pump. If you get a noise/vibration at full lock back it off a bit until it goes away and avoid turning the steering to full lock. Tell your dealer the new pump did not fix your issue.
Quick Reply: Steering Wheel Shakes
