C63 AMG (W204) 2008 - 2015
warranty question Regarding Resonator
Old 10-14-2013, 04:52 PM
MikeTc63's Avatar
C63 Coupe
Hey guys I have a 13 coupe that I leased back in june,
If I do a resonator delete will the guys at the service center gimme a hard time?
Please chime in on this guys ..I gotta buddy setup at 7pm today to do it.. I know its a very minor mod just being paranoid
Old 10-14-2013, 06:51 PM
ghiaguy's Avatar
C55 AMG, 300D-T & Karmann Ghia
I wouldn't do it to a leased car personally.
Old 10-14-2013, 07:18 PM
Mort's Avatar
Better plan to be able to reverse this mod so you can put the resonator back for lease return or you will likely be charged to put the car back to stock configuration by MB Financial.
Old 10-14-2013, 07:21 PM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
just put it back before return.. it doesn't cost that much
Old 10-14-2013, 07:26 PM
KIS007's Avatar
2014 C63 Coupe
If the dealer can show your modification caused a problem with your car then it can and will deny warranty coverage for that part or system.
Old 10-14-2013, 07:50 PM
MikeTc63's Avatar
C63 Coupe
You mean before each visit to service car ?
Old 10-14-2013, 11:47 PM
natman316's Avatar
2012 C63 2015 C300 sport
he means before returning the lease. The resonator delete should not effect anything and warranty should not be voided. to have warranty voided they must prove ur mod directly caused the problem.
My car has secondary cat delete, afe filters, kw suspension, oe tune, wavetrac etc and i still get warranty work done.
Old 10-18-2013, 11:58 PM
DuaneC63's Avatar
AMG GLC63. Audi R8
To take of the resonators you have to make one cut. So you really can't reverse it to stock without anyone noticing it. The resonators are a flow through design and add no back pressure so there is no performance to be gained. If you want to get some power, without going completely crazy with long tube headers, consider the secondary cat delete pipe which also requires one cut. Since it's down stream of the O2 sensors it won't set off CEL.
Quick Reply: warranty question Regarding Resonator
