W204 upgrade from 5" OEM Display to 7" OEM
C63
Do you have a pre-FL or FL model?
I'm really curious to see pictures of this conversion.
As for the maps you will need the DVD update for your region IMO
2010 P31 Obsidian; 1990 ZX11
Be advised, you will only have about four (4) chances to change back and forth, as the hard drive will lock in the last Region (1 or 2) at the end of your chances. But that only matters if you are trying to use Region 1 later, like NTSC DVDs.
Oh i get it now that you added the picture. You don't have the P2 package and you upgraded your screen. Nice job
If your car is a US model, you may also need to change your system from Region 1 to Region 2, so it will read the Region 2 DVD for the Middle East when you upload the map data. You will have a menu option to select Region 2 when you start the process.
