Is AllDataDIY.com worth the $30 yearly cost
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Since the samples do no include any C63, it is hard to know what exactly Alldata has for the C63.
Anyone else use it, is it worth it.
yeah, I pulled the trigger for a year.
Was reading through some of the bulletins.. and am a little pissed now. Some of the complaints I had about ticking noises (explained almost identically in the bulletins) when I took my car in under warranty, they explained as normal and would not look at them... Now I am wondering if I do actually have an issue.
At the same time, it is kinda like self diagnosing with webmd.. when you have a sniffle.. oh hey, same symptoms as ebola.. I must have ebola :P
It is just that they never performed any of the diagnostic tests recommended... Maybe it was a bad idea to read those...
Former Vendor of MBWorld
Those pinpoint tests are spot on, if you do them correctly and they point towards an issue I would take the car back to the dealer and say you had a private shop look at it using the Mercedes tests and that you think they should double check it before something catastrophic occurs and makes you an unhappy Mercedes owner
