Clamps is leaking
Clamps is leaking
Ever since i got my cat and res delete i've been hearing a little ticking sound come from under the car. I was thinking it was normal but it got annoying so I brought it to my mechanic this week and we found out the clamp was leaking. Are clamps 1 time use only? Anyways I was wondering if anyone knows the part number to this clamp.. ? thanks
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
If you're sure it's a bad seal around the clamp (not the weld itself) and the clamps are tightened all the way, you can wrap a layer of silica exhaust tape to build up the diameter and then clamp it down.
