Differential Circlips thickness Help!!
C63 AMG COUPE
Hi everyone
I m just regarding is there any circlips thickness difference between left & right side? I was mix the left and right side components up..How stupid I am !!!
If the thickness is different, please tell me:
A2303500349 bearing side-??? thickness
A2303500249 bearing side-??? thickness
Thanks.
Thanks.
07 E63 + 07 CLK63CAB
the circlips are the same size but the bearings themselves are different thickness, Try searching " Quaife LSD" install there a few blogs on the subject. \hope this helps.
It was the circlips, installed them in the wrong side. (Make sure you mark them to indicate left & right side as the thickness is different)
Left thickness: 4.1mm
Right thickness: 4.2mm
putting them in the incorrect sides was enough to create the whining noise.
Apologize James,
Apologize James,
C63 AMG COUPE
C63 AMG COUPE
Apologize James,
Apologize James,
Thanks mate!
C63 AMG COUPE
Apologize James,
Apologize James,
The circlips of mine, one is 4.0mm other one 3.9mm
that's strange...
C63 AMG COUPE
