C63 AMG (W204) 2008 - 2015
seat movement under heavy braking
Old 11-30-2013, 08:38 PM
DuncS3's Avatar
C63
Hi,
2013 507 Coupe - I have noticed that on occasion, the drivers seat back moves forwards ever so slightly under heavy or sudden braking - anyone else experienced this in their car or is it just my car?
Dunc
Old 11-30-2013, 08:53 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
I'm not sure if it's normal, but some ppl (including my car) have the same problem. It doesn't bother me, so I never got it fixed under warranty.
Old 12-01-2013, 02:06 AM
Merc63's Avatar
C63 AMG
Your knee is probably hitting the switch on the door.
Mine does all the time.
Old 12-01-2013, 03:15 AM
MBHC's Avatar
09 C63 AMG, 15 ML63 AMG, 13 S550 4MATIC
I believe this is normal since my car and two other Mercedes that I have had all did the same thing under heavy breaking.
Old 12-01-2013, 09:57 AM
rediesel's Avatar
2006 E320 CDI 2014 C63 507 Coupe 2012 E550 4M 2016 E63s Wagon
My guess is the car is putting you in a better position for a potential crash .... seat belts tighten, seats move, etc. I think it is all part of the pre-safe system.
Old 12-03-2013, 12:08 AM
SixPointThree's Avatar
G550
I think this is common to all or most C63's. But it's not related to braking. The seat mechanism actually has some slop built into it (probably not by design). When you first get into the seat of the car, do you notice that it rocks back slightly? Try moving forward in your seat (to take the weight off the seat momentarily). My guess is the same rocking sensation/noise you mention will occur.
Old 12-14-2013, 12:27 AM
DuaneC63's Avatar
AMG GLC63. Audi R8
Nothing personal.. but how much do you weigh.
Old 12-14-2013, 12:31 AM
Case1906's Avatar
AMG GTBS, AMG GTR Pro, AMG GT, C63 AMG, Porsche Panamera 4S, RX-7 FC Turbo II
I don't know, I'm doing really hard braking on track and have never noticed this other than the belts seem to tighten.
Old 12-19-2013, 04:00 AM
DuncS3's Avatar
C63
mixed opinions then - it doesn't always happen - i noticed it on track probably once or twice under heaving braking.
200 pounds btw
Old 12-19-2013, 01:07 PM
BerBer63's Avatar
2009 C63
mine does the same
Old 12-19-2013, 01:25 PM
van_rider's Avatar
2015 E63S
mine does the same. it has a slight rock to it under heavy load or braking - more evident in track environment. I'm about 185lbs. I cant say I like it.
Old 12-19-2013, 02:33 PM
2012C63AMG's Avatar
2012 C63 AMG
Ive had 2 C63's both of them did this. Next time you get in your car move the back of the seat backwards and forwards just in 1 increment, you will noticed you can use your hand to moved the setback a tad more than in other positions, I just had to find the position where it locked and it will lock if you tap the adjuster a few back and forward where you find it.
Quick Reply: seat movement under heavy braking
