C63 AMG (W204) 2008 - 2015
Tire Size Assistance - HRE 19's
Old 01-13-2014, 10:36 AM
Kriston's Avatar
C63 AMG
What's up fellas!
I'm gearing up to install all the parts I have accumulated over the winter in the next month or so.
I will be running a set of HRE FF01's:
19 x 9.5 = ET 44 Offset
19 x 8.5 = ET 30 Offset
I know the offsets are somewhat aggressive, but considering some of you are running similar sizes / offsets with the use of spacers. I figured I would try to get a nice flush stance without the spacers.
My question - the Front is aggressive, my concern is caliper clearance I may run a 5 MM spacer to clear my coil overs. Would you recommend a 225 or 235 wide tire? Im going to do something with a bit more of a rounded side wall IE: Toyo T1R or Falken 453's.
For the rears would you do a 265 or play it safe and run a slightly stretched 255.
Car is lowered with H & R Super Sport Coil Overs.
Your input is really appreciated
Kris
Old 01-13-2014, 11:31 AM
olszowa12's Avatar
'08 C63 Estate
I was running 8x19 ET30 with 235/35/19 without rubbing but that was on H&R Springs.
(OEM Multispoke ET45 with 15mm spacer).
With coilovers on the lowest setup I had this - 225/35/19, HRE 8.5x19 ET33
(ET43 with 10mm spacer).
I tried running 15mm in front but I only damaged my front fenders by doing so.
Old 01-13-2014, 01:54 PM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
I suggest u 225/35/19 & 255/30/19 to be on safe side. Stretched but safe from rubbing.
Old 01-13-2014, 02:05 PM
avery.whss's Avatar
S550 on order
whats with everyone and using 255's!?!?!?! 255s DO NOT get traction...I have 20 inch rims that are 9.5 wide in the rear sitting on 285's perfectly fine, 255 on the fronts...my car spins the 285's EASILY...Imagine how it spins 255s...I had 255s before and absolutely hated it, made the car drive like complete ****
Old 01-13-2014, 02:17 PM
Kriston's Avatar
C63 AMG
Are you lowered? If you are on stock suspension sure you can fit a wider tire.
Ideally I would have loved to go with a 275. But our rear fenders are not friendly to wide tires and lowered cars.
Roswell / Matt as always your input is really appreciated.
Old 01-13-2014, 02:23 PM
Girard@ACGautomotive's Avatar
a car
I would say the 255 is the ticket. 265 would probably rub with that offset in the rear.
Old 01-13-2014, 02:33 PM
Roswell's Avatar
Tire size depends on wheel offset.
In a perfect world, our cars should all runs 305 in the rear, but it's not doable with our fenders clearance.
Old 01-13-2014, 03:50 PM
avery.whss's Avatar
S550 on order
i shoulda mentioned i'm running a 25 series tire in the rear so it is fairly thin but still has some sidewall too it...i think canadian verisons are lower slightly then USA? if i remember correctly?
Old 01-13-2014, 03:59 PM
Kriston's Avatar
C63 AMG
Not Sure if the Canadian C63's are spec'd differently compared to the US Versions. However, I feel there are no difference in the suspension setups.
Either way it does not matter as I am on Coil Overs.
I think I will stick with 255 / 35 / 19 for the rears and 225 / 35 / 19 upfront.
Last question - For those who have coil overs - Did you require spacers to clear your coil overs upfront?
Old 01-13-2014, 05:34 PM
Mort's Avatar
I think you will want 30 series on the rear and not 35 series tires.
Old 01-13-2014, 10:45 PM
Roswell's Avatar
listen to the wheel Master!
As for spacers, I wouldn't recommend it as ur front offset is already too aggressive so adding spacers will most likely cause rubbing. I would say try ur set up as is first, if u have suspension clearance than add spacers after (if it's safe for the front fenders, or else get new wheels with better offset)
Old 01-13-2014, 11:05 PM
Roswell's Avatar
Btw, Kriston ur fronts are 19x8.5 +30mm .. So I'm pretty sure ur 225/35/19 will clear the suspension .
The only problem with inner suspension clearance is when the offset is higher than normal (i.e 19x8.5 +50mm for our front , that sunken look) or if ur car is slammed to the point u get crazy negative camber.
Old 01-13-2014, 11:27 PM
Roswell's Avatar
Oh one more thing Kriston, I got extra HRE stickers in white or grey.. Let me know if u want some, I can send u free of charge.
They look like this:
https://mbworld.org/forums/5831861-post98.html
Quick Reply: Tire Size Assistance - HRE 19's
