C63 AMG (W204) 2008 - 2015
Dynamic tune ??
Old 01-24-2014, 05:01 AM
Kaiba's Avatar
AMG
Dynamic tune ??
Hi guys ,
As I finally decided to keep my C BS after receiving my SLS BS , I'm considering the S/C upgrade.
It is clear to me that Weistec is the best option with their S3.
However , during my little research ( didn't last long with Weistec name everywhere ) I found a tuner with a S/C solution that would not affect the stock ECU... Explanations ? :
They had their own device between the S/C and the ECU that will do all the math & tune but leave the ECU completely stock.
More than that ( this is the part I'm interested in ) their device allows the driver to switch "on/off" the S/C via the Sport settings button.
"C" -> S/C off
"S+" -> S/C full power
Isn't that so cool ??
I would be all over it if Weistec had this option. This tuner says his S/C gives 680hp ( thats about the Weistec S2 power so I guess they use the same S/C)
Anyone think its possible to retrofit or adapt this thing ?
Old 01-24-2014, 07:41 AM
NellyRod's Avatar
2012 C63 AMG BS, 2010 DUCATI 1198S
Do you have a link to their page so we can see exactly what you're talking about? I'm interested in more details.
Old 01-24-2014, 07:44 AM
Kaiba's Avatar
AMG
http://www.loewenstein-manufaktur.de....php?id=86&L=1
Old 01-24-2014, 08:08 AM
NellyRod's Avatar
Looks promising, but I couldn't find any reviews of the system, or pricing.
Old 01-24-2014, 08:12 AM
mr747's Avatar
c63
I'd like to know some more info on this
Old 01-24-2014, 09:33 AM
SROC276's Avatar
2010 C63 P31 AMG
Interesting.....I wonder how they disconnect the supercharger with a switch as it's direct in a sense. Perhaps piggy back tune less aggressive....just don't know how they switch off boost per say with a supercharger.
Old 01-24-2014, 10:30 AM
alexmtl's Avatar
2013 C63 coupe P31
A tune only active in Sport mode? I approve!
Old 01-24-2014, 01:45 PM
BAD430BENZ's Avatar
360 Modena TT
why would you want a switch to turn the blower on and off if you don't want full boost , don't stomp on the pedal . when I had my Stage 3 , I could drive around at any normal driving condition in or out of traffic like a stock vehicle.....then when it was time to play , you smash the throttle and away you go .
I would think if you wanted to be stock but have power at the flick of a switch.....buy nitrous
I would like to see pricing and some sort of customer review on this thing anyway
Old 01-25-2014, 12:03 AM
roadtalontsi's Avatar
10 C six trizzle
what you are describing is called a piggy back. this is usually a terrible, last resort, cheap option. minor tuning like a change in injector size can be effectively done with a piggy back. Anything more than that and depending on how big the injector the piggy back is terrible. Pretty much a piggy back interupts the inputs to the stock ecu to "trick" them into doing what you want. It can work but is very limited. Why would you want to trick something, when you can use the very powerful and complicated tuning algorithms of the stock ecu to your benefit. what is your fear of running a tune on your ecu? Also blower on/off switch is pointless. the car already gets terrible mpg, the blower "robs" a little torque to make alot more. So when you think about that statement read it closely. Having a switch is something only necessary for emissions or maximum fuel economy which is a joke on a 63 car anyways.
So pretty much every statement you've made is a bad idea, Id tread lightly.
Old 01-26-2014, 04:02 AM
Kaiba's Avatar
AMG
You really think I care about mpg ????
I like the idea ( like others it seems ) to either stay stock on C or have full power on S+.
Old 01-26-2014, 09:15 AM
estrellajon's Avatar
C63 ///AMG P30
My thoughts exactly. You can't just turn off a S/C. It's mechanical with a belt attached to your crank pulley. The S/C pulley dictates the spin of the twin screw which the amount of air goes through the chambers. Any fuel discrepancy will make it lean or rich.
Old 01-26-2014, 12:31 PM
10 C six trizzle
the 55k motors have a clutch on the supercharger. The fuel calculations are pressure based and throttle based known as speed density. works just fine, also has a second throttle to bypass or the supercharger incase of over boosting. Interestingly though with the belt off the blower the engine vacuum will still turn the blower just fine.
I understand mpg isn't important and that's what i was trying to get at - that emissions and fuel consumption are the only advantage of this overly complex setup. You're much better off just getting one of the turbo cars, have the tuner set up a switch for a boost controller so you can be slower or faster depending on what you're wanting. It'd be way cheaper, simpler and reliable.
Old 01-26-2014, 02:20 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
<snip> You can't just turn off a S/C. It's mechanical with a belt attached to your crank pulley. <snip>
Sure you can. It's called a clutch. All E55s have one straight from the factory.
Quick Reply: Dynamic tune ??
