Double checking rim sizes
I have a C63 Edition 507 and have found a bunch of errors with the owners manual. Could someone confirm that these are the correct size and offsets for my car? Apparently Toyo makes an all season that is the correct size tire, but I want to use some cheaper rims for the winter..
Front 8x19 with 45mm offset?
Rear 9x19 with 54 mm offset?
Thanks,
Ed
Thanks,
Ed
If the 507 wheels are the same size as the 19's AMG multispokes, than yes these are the right size.
The ETs will likely be printed on the inside of the hubs if you care to look. Those ETs look correct to me based on other wheels (18" & 19") that have been used by AMG.
