anyone try out these tail lights?
Go to the regular W204 section. you'll find others who have bought these. Fitment is not perfect, and I've heard that there is some buzzing noise coming from them that can be fixed by cutting a wire. Supposedly no error messages.
found the thread again: https://mbworld.org/forums/c-class-w...ext-mod-5.html
Before you go OEM, I advise you read around the forum. They require a good amount of work as you need your current rear SAM reprogrammed or find a 2012 rear SAM unit somewhere. If you don't have the SAM unit coded for LED tail lights, they will not function properly.
