C63 AMG (W204) 2008 - 2015
Springs questions
Old 02-17-2014, 07:38 AM
momo style's Avatar
C 63 AMG 507 Edition
Springs questions
If adding a little drop on the car by only using spring, ( HR sports ) can it might dammage the shock absorbers? Like leaking?
Or there is no worries with that
Thanxs
Old 02-17-2014, 12:18 PM
Thrilla's Avatar
2014 C63 AMG 507 sedan
The suspension is a wear item. Over time it will need to be replaced. Adding lowering springs can increase the rate of wear and failure. When and how much is still to be determined. With that being said, a lot of members have been using H&R springs for many years and miles and still going strong. Safe to say, you will be fine with them for a long time.
Old 02-17-2014, 01:09 PM
momo style's Avatar
thanxs
Old 02-17-2014, 01:17 PM
Ayrton's Avatar
scooter
Suspension has a set travel and spring rate range, and as long as you stay in that range, the wear is within spec.
Basically you will not wear the struts and shocks any faster with lowering springs (unless you drastically increase the spring rate).
Quick Reply: Springs questions
