C63 AMG (W204) 2008 - 2015
Couldn't put car into gear...
Old 03-06-2014, 11:06 AM
Manofsteelpt's Avatar
S63
Started my car (09 CLS63) up this am for work and I couldn't put it into reverse. The shifter moved to the right, but that was it, I couldn't pull it back to R, N or D. It appeared as if it was locked... Turned the car off and restarted and same thing. Turned it off again and restarted and all was well.
Any thoughts on this?
Old 03-06-2014, 07:27 PM
Duals1ns's Avatar
MY2010 6.3///AMG Markus Jaudes
Were you stealing the car!(lol). Sorry, can't help maybe someone will.
Old 03-06-2014, 08:11 PM
klapkakid's Avatar
2013 C63 P31 Obsidian Grey
Might try reseting the TCU?
1. Turn on the key to the "on" position.
2. Press the accelerator to the floor and hold for 5 seconds
3. Turn the key to the off position but don't remove the key. Then release the accelerator.
4. Wait for a couple of minutes then try starting it.
Hopefully this helps
Old 03-06-2014, 08:50 PM
S63
No, didn't steal it lol...
I could try the ecu reset next time, if the restart doesn't work. I didn't/don't know what the deal was with it. Thanks tho.
Old 03-06-2014, 10:21 PM
roadtalontsi's Avatar
10 C six trizzle
could be alot of things. Spill anything in the shifter lately. What comes to mind is a stop lamp switch or shifter assembly.
Old 03-07-2014, 08:12 AM
S63
No, nothing spilled...
Old 03-08-2014, 07:02 AM
edwardsflight33's Avatar
'16 CLS 63 S
Try turning the steering wheel to one side or the other. My dad used to have a fan and similar thing happened. If he turned the key to "On" when the steering wheel wasn't locked to the far side you couldn't shift out of park.
Trick ended up being: Put the key to "Accessory", shift to nuetral, turn key to start vehicle. Or just turn the wheel all the way to left or right. Hope you've got it working and it's not a recurring issue.
Quick Reply: Couldn't put car into gear...
