NEW RIM QUESTION!? HELP!!
hello, I am new to the forum so bare with me.....my rims just came in today and unbeknownst to me all four of the rim are 19x8 +45 offset and to my knowledge i thought fronts and rears are different specs....i called the seller to clarify and told me that i can run all fours with tires 235/35/19s?....any truth in the matter? any help would be awesome... FYI i have a 2012 c63....thanks in advance
They should have a staggered fitment....8.5 fronts and 9 rears....I think the sizes are 235/35/19 front, and 255/30/19 rears (OEM)...are these OEM wheels? I know for my winter OEM they came with 8" wheel all round for snows....
no there not OEM, I had hit a pot hole with my OEM 18" and bent two of the rims so i bought these off ebay...so i should i probably return them hah...the 19x8 would not work for the fronts?
http://m.ebay.com/itm/201054238306?nav=VI
Here is the rims I purchased if it helps...anymore input would be great as I plan to call thr seller early AM
absolutely return them. as GRP said.. unless they are being used jsut for snow with winter tires on them, they are not at all what you need. personally im running Modulare M14s 19x8.5 front 19x10 rear.. my winters are 18x8.5 front 18x9 rear.
try Tirerack.com they have nice wheels at great prices for our cars and the proper setup needed/options available when you put in your make model etc..
2014 C63 AMG 507 sedan
advice
Check the aftermarket wheel thread, people usually post the size and offsets along with tires with pictures. The wheel fitment for our cars are difficult since the offsets are shallow, and width in the rear is limited.
You can avoid all the headaches of picking the wrongs sizes and offsets by buying a used set of quality rims with correct fitment. There's one in the wheel and tire section for sale. (shameless plug)
https://mbworld.org/forums/wheels-ti...-hre-563c.html
