stealership story
stealership story
there are lots of stealership stories on here, but I had to share this one (and they are otherwise really cool guys, so I'm not going to name names). took my car in for basic service, and my left fog bulb is burned out. guess how much they are asking to swap it out? $91 and change. lol. nuts.
g**damnit. lol. afaik there are access panels on the undertray to get to the fogs. I honestly never use them and I can't stand how they light up individually when I turn the steering wheel, so I'm probably not even gonna change the burned out bulb.
Yeah, I'd much rather have active illumination with bulbs that turn as you turn, but instead they decided to make your lights look gimpy like your car is blinking with one eye.
Fog light can be changed without taking front bar off.
Just access panel in front of wheel well.
I have done it myself. Very easy.
Just change it yourself. H7 bulb.
looks like you can make an easy 100US$! jk. yeah, I did some research and found that it can be done via the wheel well or the panels on the undertray, although I've personally never looked.
2013 ML 350 Bluetec
I had the same issue left hand brake light out, cost me 45 cents and a few minutes, wasn't so lucky with the key though that cost me $730, those stealers they sure have a sense of humor.......
yeah. this same stealership sold me a new key at cost. and then they do this thing with the fog bulb. at least they are good at the give and take.
WTF??? $91 to change a bulb? the dealership i take my car too changed my front fog light bulb + gave me the bulb for free and they also did the same with a rear tail light...thats wild are you sure it isn't some young dude pocketing the money? lol
AMG893 is right though..just access it through the wheel well
Then that definitely sucks! I know my tech empties out my oil cooler for me. Unfortunately for you, they are quoting the amount of oil based on engine specs, because the oils are coming in 50 gallon drums.
I'm sure some of those bottles when in the tech's trunk.
Check out my DIY... be thankful is not the housing... dealer charge around +$400
https://mbworld.org/forums/c63-amg-w...g-housing.html
