C63 AMG (W204) 2008 - 2015
K&N filters = CEL
Old 03-20-2014, 09:06 PM
ZC63's Avatar
2009 C63 AMG sedan
K&N filters = CEL
Just dropped in K&N's and I was worried... Sure enough a few start ups later CEL is on. MAFs must be to sensitive, anyone have a solution besides removing them and going back stock?
Old 03-20-2014, 09:12 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
One step at a time grass hopper, put the charcoal filters back in, for the .2HP you are going to gain you just created a cel battle with your car. Ran K+N filters for 40 years in all sorts of cars, and even my 63's, no issues what so ever.
Those paper filters you removed were used up long ago.
Old 03-20-2014, 09:26 PM
dubzAMG's Avatar
2010 C63 AMG FBO, 2014 E63 AMG S
AFE makes a non-oiled drop in filter.
Old 03-20-2014, 09:39 PM
ZC63's Avatar
2009 C63 AMG sedan
Thanks critter that's what I was thinking about doing.
Old 03-20-2014, 09:40 PM
Critter's Avatar
Pay careful attention when you reseat the air box covers, they can be tricky.
Where you from TO.
Old 03-20-2014, 09:46 PM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
Weistec dry filters are awesome and make more power than K&N. My SLS was at K&Ns facility for a dyno shootout about two weeks ago. K&N put their ilters in my car and I lost a couple hp on their dyno lol. Re-installed the Weistec dry filters and got the hp right back.
You can even go to K&Ns instagram page and look back about two weeks and see a video clip of my car on their dyno. FWIW, I won the dyno shootout
Old 03-20-2014, 09:48 PM
Ayrton's Avatar
scooter
I honestly think this has more to do with the filter (and or cover) not being seated correctly. I dropped in the oiled AFE with my ROW boxes and that was a 1,000 miles ago.
No CEL
Double check everything is seated correctly, and snug the bolts in a crisscross fashion. Maybe the MB maf is super sensitive, but it seems unlikely considering the number of cars running K&N filters.
Old 03-21-2014, 12:28 AM
ZephyrAMG's Avatar
2010 Irridium Silver MB C63 AMG Sedan
Man that's one dirty air intake. Looks like you have gobbs of mud in one of them. Your filters look like they have been used as mud flaps on a truck.
Start with cleaning out your intakes--CAREFULLY. As you don't want to be shoving any muck in deeper.
Then hose down your K&N filters and clean them. Wash them and dry them well.
You could also wash your charcoals. But make sure you dry them really well, perhaps in the sun and over a few days.
Re-install and make sure its seated well. Should be fine.
Been running K&N for over 5K miles and no issues...
Old 03-21-2014, 12:36 AM
Merc63's Avatar
C63 AMG
What about that nice K&N sticker that was on your car lol
Old 03-21-2014, 12:45 AM
EDgineered's Avatar
2005 C55 black on black aka DVS C55, 2007 C230 sport silver on black for the boss
Nice. Did you ever meet up with the guys with the turbo SLS?
Old 03-21-2014, 02:33 AM
GRP
GRP's Avatar
2010 C63
I have had no issues with the AFE dry filter.
Old 03-21-2014, 09:50 AM
jrcart's Avatar
No I did not. I ended up flying out of Montery after the last event. I had planned on flying back out to California last weekend but something came up so I could not. In PM'ing with the owner of the tt SLS, I do not think it got it's new clutches installed so he would not have been able to run me anyhow.
jrcart's Avatar
Yes, lol, they make me run all kinds of ridiculous sponsor stickers for the event.
Old 03-21-2014, 01:45 PM
avery.whss's Avatar
S550 on order
I left my K&N's on a cardboard box once over night...the next day the cardboard looked like it had day old pizza sitting on it with the amount of grease that came off the K&Ns...I got CEL also from the K&N's...I use APE now..I still have CEL but not because of the filters my car just is stuck on perma CEL the dealership told me basically
Old 03-21-2014, 01:50 PM
jrcart's Avatar
What code are you getting? Your dealership sounds like a moron. No reason you should have a permanent CEL, unless you did a ct delete or something and did not turn off the proper sensors. Can you clear the code? If you can clear it does it just pop right back up? Sounds odd and I would think you could get it taken care of.
Old 03-21-2014, 01:54 PM
avery.whss's Avatar
S550 on order
lean 1&2 ...they even had TIPs canada get involved...they told me they have no clue..the only thing they told me to do was "replace the ECU" because they think the tune screwed the car up but even on stock file CEL comes on .replaced purge valve and some other things...yeah I did a 2nd cat delete...what sensors do you need to turn off? Yeah if they clear it, it comes back on within 50km ...the car doesn't run bad or anything
Old 04-03-2014, 09:35 AM
vtune's Avatar
E92 335i / C63 AMG / GSX-R 600
I got K&Ns because they were available locally. Installed and removed Charcoals - no CEL issues. When I removed the stock filter I saw a lot of debris in the intake box, had to grab a vacuum and clean them up.
The difference is tiny, the exhaust sounds a bit louder.
Old 04-03-2014, 10:01 AM
Autosport7's Avatar
C63 AMG
I am also running K&N's.
No CEL's thus far, knock on wood. I too had a bit of sandy dry dirt in the box that I spent a good bit of time making sure I got it all out prior to the K&N install.
The one thing I like about the K&N, is the oil. I'm hoping when I inspect the K&N's here shortly, all that dirt wont be sitting in the bottom of the box and the oil will have done its job.
Although, I think if the filters are too oily, they will gum up the MAF sensor and kick a CEL. I recommend letting them sit outside of the box for a few days on paper towel before installing.
Old 04-04-2014, 03:37 PM
Sincity's Avatar
Been running them since less than 1000 miles on the odo and now I'm at 12k. No issues. I did clean the MAFS at 10k mile as part of my routine MAF preventive service. Check that all four corners of the box are properly seated and sealed. If you still have a CEL, then you must belong in the JonsC63 group.
Old 04-04-2014, 03:52 PM
Kriston's Avatar
C63 AMG
I installed my Renntech intake a few nights ago and it came with AFE Pro-dry filters. No CEL's and I replaced my entire Intake assembly.
Old 04-06-2014, 01:59 AM
mikeyyyallday's Avatar
2011 MB C63 AMG. 2014 MUSTANG COVERTIBLE V6. 2010 MUSTANG CONVERTIBLE V6.
does replacing stock air filters add any hp? and also does it void factory warranty?
Old 04-06-2014, 06:51 AM
Kriston's Avatar
C63 AMG
The air boxes on the North American cars has 2 filters a charcoal filter and the regular paper filter. By removing the charcoals and replacing the paper filter with a high flow one like AFE / K&N etc. You do get a few extra ponies. Nothing crazy, but its worth the 100 bucks you will spend on the filters.
Old 04-06-2014, 01:47 PM
has anyone gotten CEL from the AFE or weistic dry filters?
Old 04-06-2014, 01:59 PM
Dogtag114's Avatar
2009 c63
I'm dropping in Weistic filters next weekend... was waiting for warmer weather. My biggest fear is opening it up and seeing that the previous owner already put them in and I just need to clean them...
Old 04-06-2014, 02:18 PM
badbenzz's Avatar
AMG GTS, Ford Raptor and Tesla Model 3 dual motor
Got my Weistec filters in and love em
Quick Reply: K&N filters = CEL
