C63 AMG (W204) 2008 - 2015
Time to replace my C63 front brakes
Old 03-24-2014, 09:42 AM
Wack's Avatar
C43 AMG CAB & VIPER
Hi All,
My dealer tells me that it will be time to replace my front brakes in the coming months. I've always done my on brake jobs without any issues and wonder if the C63 is any different from your "standard" brake job (anything special other than you MUST replace brake sensor ?)
I 've been told that since this is my first brake job on this car, I can probably do just the pads and sensors and I wonder what you guys think about that ?
I've found OEM parts on ecstuning.com that seem like a good deal at $220 + sensors and wonder if I "NEED" to get the rotors as well.
Please keep in mind, the car is for sale so I'd like to spend as little as possible on it (without doing anything "wrong")
If I need the rotors too, can anyone comment on weather or not this is what I need for a standard 2011 C63: http://www.ecstuning.com/Mercedes_Be...ors/ES2612254/
Thank you for your time
Old 03-24-2014, 11:46 AM
tfthach13's Avatar
'09 C63
The rotors lasts quite a long time, so you should be good...but you should check the thickness just to be sure.
I personally like Porterfield R4-S pads since they produce very little brake dust compared to OEM pads and are rotor-friendly. If you really want OEM pads, FCPEuro has some pretty good prices.
EDIT: Those rotors seems right if your C63 doesn't have the performance package, which means you have the two-piece rotors instead of the standard steelies.
Old 03-24-2014, 12:13 PM
Wack's Avatar
C43 AMG CAB & VIPER
Originally Posted by tfthach13
I personally like Porterfield R4-S pads "brake dust"
Thanks !
Will look in to the R4-S, I'm also quite annoyed with the overabundance of brake dust from the OEM pads.
Old 03-24-2014, 12:46 PM
Girard@ACGautomotive's Avatar
a car
Originally Posted by Wack
Thanks !
I have porterfields in stock. They are great, no noise, no dust, great stopping power.
Let me know if you need a set.
-Tal
Old 03-24-2014, 01:49 PM
natman316's Avatar
2012 C63 2015 C300 sport
Do we have to replace sensors as well?!
Old 03-24-2014, 01:51 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
not if they haven't been triggered.
Old 03-24-2014, 02:40 PM
natman316's Avatar
god damn mine literally just came on...should have replaced them earlier when my SA told me about pads being low.
Any idea how much they cost?
Old 03-24-2014, 02:57 PM
god damn mine literally just came on...should have replaced them earlier when my SA told me about pads being low. Any idea how much they cost?
don't be so hard on yourself; I think they cost around $15 each.
Old 03-24-2014, 04:51 PM
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
I believe there just two; one for front and one for rear... correct?
Old 03-24-2014, 04:59 PM
I believe so. although for some reason I am recalling that there's only 1. maybe. I can check later, or I'm sure someone will chime in to tell me I'm wrong.
Old 03-24-2014, 05:04 PM
Valvestud's Avatar
There's definitely two, just not sure if there's four.
Old 03-24-2014, 05:06 PM
then it's 2, but I can verify that in a couple of hours from now. (I either thought it was 4, and there ended up being two, or I thought there was 2 and there ended up being 1).
Old 03-24-2014, 05:25 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
It is 2 sensors.
As for Op if you plan on selling the car OEM pads would be just fine. Check any parts website for better pricing than stealership.
You don't need to change your rotors unless they are worn out which shouldn't be the case. They usually last longer. How many miles on your C63?
Old 03-24-2014, 06:26 PM
douwe22's Avatar
there is only 2! just did mine a couple of month's ago, there is one in the front and one in the rear.
Old 06-16-2014, 09:54 AM
Wack's Avatar
C43 AMG CAB & VIPER
So I have ordered replacement R4S pads front and rear, and in the time it took them to arrive, I have noticed my brake pedal started to pulsate a little bit at higher speeds.
I'm guessing the front rotors are slightly warped and that this is an indication that I should replace them at the same time. (I'm at about 45k miles)
I've looked everywhere trying to find suitable rotors but I'm getting all sorts of uncertain information. I was hoping I might get a little help here.
2011 C653 AMG, NON perf pack, looking for replacement front and possibly rear rotors, something reasonable that wont break the bank but still stop the car well (stock ones are fine for my needs), Especially since I'm returning the lease soon. Preferably something that looks like stock (cross drilled) so the dealer won't ***** when I return the lease), and of course that is a good match with my portfield R4-S pads).
As usual, I thank you all for your help !
Old 06-16-2014, 09:59 AM
Merc63's Avatar
C63 AMG
-Tal
I'll take a set front and rear, how much?
Old 06-16-2014, 11:47 AM
shades's Avatar
09 C63, 11 Cayenne S
-Tal
Hey Tal, can I get a quote from you on two piece front rotors shipped to Toronto
Old 06-25-2014, 06:41 PM
Former Vendor of MBWorld
RacingBrake's Avatar
CLS550
Racingbrake offers light-weight two piece rotors for your C63 AMG Mercedes
Front Two Piece Rotors - $1,495.00
(Front include brake pads)
Rear Two Piece Rotors - $1,138.75
Weight
Front
OE one-piece 36 lbs.
OE two-piece 29 lbs.
RB two-piece 24 lbs.
Rear
OE one-piece 21.5 lbs.
RB two-piece 16.0 lbs
We offer the option to purchase replacement rings for a fraction of the cost,
Saving some money when its time to replace the rings.
Old 06-25-2014, 07:07 PM
Starky_'s Avatar
'10 C63 AMG
Would these be direct replacement for a 2010 with the PP?
Old 06-26-2014, 12:44 AM
donaldt's Avatar
C63
any cheaper alternatives on rotors but still save some weight over the stock ones?
what other pads do you guys recommend for lower dust but more stopping power?(could live with a slight noise)
Old 06-26-2014, 02:15 PM
CLS550
Yes they are.
they come with our ET500 brake pads that feature a low dust with little to no squeaking and provides additional stopping power over stock pads.
Check out some of our reviews about or rotors and brake pads.
World's First: RacingBrake 2-Piece Brake Rotors
https://mbworld.org/forums/sl-class-...squealing.html
https://mbworld.org/forums/sl-class-...ml#post6057706
http://www.e90post.com/forums/showthread.php?t=474395
Old 06-26-2014, 04:53 PM
alpha26's Avatar
GTR R35 1300whp, C63 Weistec stage 3
Yes they are.
Does 380 mm front rotors will fit on non-pp calipers ?
Old 06-27-2014, 12:46 PM
CLS550
Our two piece rotors are 360mm, direct bolt-on for PP and non PP c63 AMG's (W204)
Old 06-27-2014, 04:42 PM
alpha26's Avatar
group buy ?
Old 06-27-2014, 04:52 PM
SROC276's Avatar
2010 C63 P31 AMG
group buy ?
+1 on group buy
Quick Reply: Time to replace my C63 front brakes
