C63 AMG (W204) 2008 - 2015
20" wheels - tire configurations
Old 03-27-2014, 01:02 AM
dragonAMG's Avatar
12' C63 P31, 06' Supercharged Range, 08' BMW 550i
Hey guys.... are any of you running 285/25/20's in the rear on your lowered 63's? I'm trying to figure out if I can get by without rubbing... help would be appreciated. Thanks!
Old 03-27-2014, 07:38 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
It depends on your wheels offset?
Old 03-27-2014, 12:00 PM
dragonAMG's Avatar
Hey Roswell... the rear offset is 51
Old 03-27-2014, 12:53 PM
C63-AMG's Avatar
2009 C63 2016 AMG GT S
I'm running 285/25/20 I do rub over speed bumps and sometimes and with two adults in the back. Mine is not lowered.
Old 03-27-2014, 01:40 PM
dragonAMG's Avatar
Thanks! What tires are you running? Do they stick out or are they flush with the fender? Do you happen to know your wheel offset?
Old 03-27-2014, 02:18 PM
Roswell's Avatar
I doubt u can make it work with +51. U would need +55 to clear the fenders or roll the little bit of fenders at the worst case scenario.
Old 03-27-2014, 03:03 PM
dragonAMG's Avatar
So you think if I rolled the fenders I would have no problem?
Old 03-27-2014, 03:36 PM
Roswell's Avatar
If u look at the rear lip, there is not much material to roll.. Some will say is enough to make a difference, but in my opinion it's not worth the risk.
Rolling the rear fenders can cause paint cracking or chipping , and can separate the steel sheets where the welds are which might cause rust in the long run.
Also another option would be to shave few mm off the back plate of ur rear wheels to bring down the offset. But u should consult a professional to see how much material u got. It has been done on HRE wheels though.
Old 03-27-2014, 06:25 PM
avery.whss's Avatar
S550 on order
285/25/20 here no issues
Old 03-27-2014, 06:34 PM
Roswell's Avatar
Avery, what offset are ur Vorsteiner ? Any fender mods?
Old 03-27-2014, 06:41 PM
avery.whss's Avatar
S550 on order
not to sure on the offset i can't find it but it's 10 wide in the back 8.5 front and no fender modes, i asked about going to a 30 series but i can't or it will rub..although i can goto a 295 if i wanted too
Old 03-27-2014, 06:45 PM
Roswell's Avatar
I'm so jealous. I can't even get away with 275/30/19 on 19x9.5 +50mm & now I'm hoping to clear with my new set-up at 19x10 +50mm with the same 275/30/19 (which I know they will rub)
Old 03-27-2014, 07:25 PM
avery.whss's Avatar
S550 on order
is it all due to the offset of your wheels? you're lowered right?
Old 03-27-2014, 07:54 PM
Roswell's Avatar
Yes I'm lowered, and my offset is +50mm which works perfe with 265/30/19 from my experience. But I can't get away with 275/30/19, it rubbed on the passenger rear over bumps.
Old 03-27-2014, 10:15 PM
C63-AMG's Avatar
They are pretty flush, might stick out 1/8 - 3/16 on an inch. Tires are Falken. Not sure the offset :-(
Old 03-28-2014, 01:47 PM
dragonAMG's Avatar
Thanks guys for the help!
Quick Reply: 20" wheels - tire configurations
