C63 AMG (W204) 2008 - 2015
WaveTrac Diff
Old 04-01-2014, 09:45 AM
AMGangster's Avatar
2010 C63
WaveTrac Diff
When installing the WaveTrac, do you have to replace the bearings for the half shaft?
Old 04-07-2014, 01:11 AM
ClivePratt's Avatar
2013 c63 amg coupe, 1994 porsche 928GTS, 1988 e430
You can use the originals as long as you can get them off without damage, i did it without a problem, make sure you use inner and outer from the same side as they wear together and put them back on the same side of the diff they came off, pretty sure the outer section of the bearing is also the preload spacer, also make sure the c clip is lined up with the oil holes. you will need a press to get it apart, some wavetrac diff go straight in some require a little bit of grinding to the housing
Quick Reply: WaveTrac Diff
