C63 AMG (W204) 2008 - 2015
retune for headers
Old 04-02-2014, 01:36 AM
DavidZhu's Avatar
2021 C63S AMG, 2020 Mclaren 600lt Spider
retune for headers
So i got the eurocharged V4 tune on my car about 6 month ago and now im throwing headers on as well. would i need a retune after i get the headers? im getting different information from people. and if i need a retune how much more gains would i get verses if i didnt get a tune? thanks.
Old 04-02-2014, 02:28 AM
aussie e55's Avatar
2009 C 63
contact eurocharged
Old 04-02-2014, 02:41 AM
Merc63's Avatar
C63 AMG
Yes you need a different tune.
Old 04-02-2014, 02:55 AM
mr747's Avatar
c63
Yes you will need a retune it will run really rich if you don't
You also get a check engine light
Old 04-02-2014, 04:45 AM
DavidZhu's Avatar
so if i dont get a tune ill get a check engine light? andn what do you mean by runing rich?
Old 04-02-2014, 07:15 AM
AMG893's Avatar
2010 C63 Estate
Running rich means it will cost you more (gotta be rich)
Old 04-02-2014, 07:48 AM
mr747's Avatar
c63
You will need a tune to lean the mixtures out a bit
You will most likely get the engine light and maybe require some new oxy sensors
Old 04-02-2014, 08:36 AM
SPONSOR
loungn14's Avatar
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
yes you will need a retune
Old 04-02-2014, 12:18 PM
Merc63's Avatar
C63 AMG
It will run lean, really lean.
More flow more air, and same amount of fuel.
Old 04-02-2014, 01:33 PM
anthonymckay's Avatar
2013 C63 AMG
You need a retune after installing headers because you're significantly altering the airflow through the engine, which is going to affect your AFR (Air to Fuel Ratio). Your current fuel mapping is based on the assumption that you have the stock headers/airflow. You're also relocating your O2 sensors. Will it "run" without a tune? Sure. Will it be running correctly? Not so much. If you run a lean AFR (more air/too little fuel) you run the risk of burning up your engine.
Old 04-02-2014, 05:40 PM
mr747's Avatar
c63
My car ran really rich and then fouled the oxy sensor
Old 04-02-2014, 05:59 PM
Merc63's Avatar
C63 AMG
Strange tuners says lean and makes sense it would go lean from more air.
Maybe your o2s were messed up
Old 04-02-2014, 06:25 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
It makes sense indeed to think you would run lean after installing headers. So not too sure why yours was rich...maybe an aussie thing
Old 04-02-2014, 08:23 PM
mr747's Avatar
c63
MAYBE LOL
Old 04-02-2014, 08:30 PM
MaroonC63's Avatar
2009 Barolo red C63 AMG (SOLD).13' P31 c63 coupe 2012 porsche panamera
HAHAHAHAHAAHAHAHAHAH
Yes. Definitely need to retune. Just email Jerry, he will take care of you!
Old 04-02-2014, 09:29 PM
avery.whss's Avatar
S550 on order
my cars been running "lean" for months with CEL I just have 2nd cat delete..MB and no one on this forum has any idea whats wrong, (ive replaced everything) I've had no issues..atleast i dont gotta clean the pipes every 3 days now, so no i don't think running leans gonna blow the car up seeing mines been running lean for 5months+ and i beat the hell out of it
Old 04-02-2014, 09:56 PM
JPetros2008's Avatar
2016 AMG GTS
A little unrelated...
But do I have to get a retune if I have replaced the secondary cats with straight pipes and replaced the resonator with an h-pipe?
Old 04-02-2014, 09:57 PM
avery.whss's Avatar
S550 on order
from my knowledge no. I have straights and jerry told me no
Old 04-02-2014, 10:56 PM
DavidZhu's Avatar
i called eurocharged and they said i need a reflash of my current tune
Old 04-03-2014, 12:23 AM
BO Knows's Avatar
2010 C63, 2007 X5
Eurocharged may be coming to San Francisco soon. ASP in Daly City is trying to set up a dyno day soon.
https://mbworld.org/forums/w211-amg/...yno-day-9.html
Old 04-03-2014, 12:38 AM
AMG Boost's Avatar
2010 C63 P30
Thank god someone on the forum knows what they are talking about lol.
Yes it will be lean. Headers free up alot of flow and your AF ratio will drop. This is dangerous because it can cause detonation.
Rich is when you have to much fuel. Also the 02 sensor could of been fouled because you removed your cats.
Quick Reply: retune for headers
